- Thank you received: 44
Ridin in the Rain
- jeffasaki
never ride outside of your ability
78 Z1R
78 KZ1000
76 KH500 gone
71 HS1B 90
81 GS 1100 gone
80 PE400
02 KLR
Ontario Canada
- Calico
81' KZ750LTD 4 CYL
82' KZ750LTD 4 CYL
- KZ250LTD
- Thank you received: 16
79 KZ1000ST
Past:
Many.
- Kevin STP
A couple of near misses with 4 wheeled cellphones have made glad that I was cautious and aware.Cape Cod is a busy place full of distracted drivers and rain really increases the pucker factor.I have been on a couple dirt roads to experiment with loose traction and was suprised at how far I can slide locking up the rear brake at even low speed(20mph).With me and a full tank it's close to 800lbs,a big difference from My old Suzuki 250 with huge knobbies.Back then my Dad,who used to race at Laconia told that I should practice laying it down with control to avoid panic when I pushed it to far,Learn the limits-Wear the right gear and you be more able to make a life saving decision.
83 Spectre 750
- djturnz
- Thank you received: 5
When I get caught in the rain, I try to avoid puddles. My rain riding gear is a slightly wetter version of my dry riding gear.
1982 KZ750 (4) LTD
- damarble
- Thank you received: 13
djturnz wrote: At what speed will a motorcycle hydroplane?
On that note, I once went through what I thought was a puddle on a dirtbike at pretty good speed. Turned out to be waist deep and deep water slows you down better than brakes, which I learned while going over the bars and taking a bath.
Go green, buy a Kawasaki!
82 KZ750M CSR Build Thread
89 ZX600C Streetfighter
- Thank you received: 2829
Kevin STP wrote: I used to work a second job and commercial sandblasting was part of it with minimal protective gear,I wouldn't consider riding without a helmet,usually with a full face shield.They have been chip coating quite a few roads in my area and for added pleasure it maximum bug season.I will remount my windscreen when I come up with a better way to mount the front turn signals as they interfere as is.
If you plan to practice laying down your street bike make out your will first and get hefty life and health insurance policies. :blink: What you could do is find a very large empty parking lot and very carefully see how your bike reacts in the rain and in dry weather. Be sure to practice dry and wet. Keep in mind that 80% of your stopping power comes from the front brake, so use it generously on dry pavement. But also be aware that it can slide on wet or oily pavement, so the key to stopping safely under those conditions is to allow plenty of space between you and anything up front and don't go faster than is prudent. Also, understand it is important that you keep high quality tires in excellent condition on your bike. I've seen folks with worn out tires riding on the street. The first time they get caught in the rain they are in for a nasty surprise. Ed
- OnkelB
- Thank you received: 80
650ed wrote:
Paint stripes on the road are slippery when they get wet so use caution when riding on or crossing them.
Same goes for manhole covers and setts (cobblestones).
77 KZ 650 B1, 82 GPz 1100 B2.
- Kevin STP
83 Spectre 750
- Kevin STP
83 Spectre 750
