Ridin in the Rain
- Kevin STP
83 Spectre 750
- Thank you received: 2829
Paint stripes on the road are slippery when they get wet so use caution when riding on or crossing them.
Do not ride in the center of a lane; try to ride where the car tires normally contact the road. The reason is that oil dripping from cars generally lands in the center of the lane and accumulates. Once the road get wet the oil can get really slick. Ed
- kzcurt
- Thank you received: 21
and eyes windshield no problem if not it pretty hard to see in the rain anywhere close to dusk or dawn...
2 cents done
Flag carrier #23
9 @ 50-2053,
- jeffasaki
- Thank you received: 44
remain in control
keep visor clear
if it gets real heavy stop
wait it out
it can suck but just adapt according to conditions
as long as you feel comfortable ride
if youre unsure just stop until you feel comfortable again
if youre 5 miles away from shelter slow down and deal with being uncomfortable
and make it there in one piece
if youre in the middle of nowhere stop and wait it out
best advice is SLOW DOWN!!
5mph is better then no mph
78 Z1R
78 KZ1000
76 KH500 gone
71 HS1B 90
81 GS 1100 gone
80 PE400
02 KLR
Ontario Canada
- Thank you received: 2062
- Tomolu5
- Thank you received: 45
Mine:
04 Honda rebel 250(wifes)
04 GSXR 750(bolt on galore)
98 CBR 600F3(filter, pipe, adjustable cam sprokets, dyno tune)
76 KZ900A (LTD gauge pods, crash bars, LTD(style)pipes, dyna coils and ignition,headwork and mild port cleanup by cavanaugh racing, K&N filter pods, heck I dunno.
- MFolks
- Thank you received: 540
Troubleshooting A Wet Motorcycle (Won’t Start/Run)
1. When motorcycles get wet, many things can happen to prevent normal starting and running.
2. Ignition coils, due to their mounting location under the gas tank, can overheat if sufficient air flow is not provided causing minute cracks for moisture to get in shorting the coil.
3. Sparkplugs wires and caps need to be replaced as the heat from the engine makes the wires(High Tension Leads) get brittle causing the insulation to fail. The caps contain a resistor to limit the RFI(the snap and pop heard on radio’s) that will fail, again from heat/age. They can be checked with a multimeter ,and will test at 5000 ohms.
4. Most Japanese motorcycle electrical connectors are open at the rear, letting in moisture, that will collect on the male and female pins/sockets
causing a short, blowing a fuse or creating corrosion limiting current flow.
5.Check the right handlebar switch pod for signs of corrosion or broken wires on the run/stop switch. Some older Kawasaki’s are experiencing broken/crumbled solder joints in switches. If needed, I have a repair procedure, just ask.
6. I recommend buying a spray can of “De-oxit” electrical contact cleaner/preservative available at Radio Shack Stores in the U.S. or any other electronic supply store. www.deoxit.com is their website.
7. I’d advise not using WD-40 on any electrical connection/fuse clips as it over time becomes a non conductor(more like an insulator).
8. If the popular “Pods” type air filter is used and gets wet, it will act like having the choke on causing a very rich condition. The only repair for wet pods is to remove them and either using an oven set at 250 F, a wet/dry shop vac to vacuum the moisture from the filters, or a air nozzle at low pressure to blow the water away.
9. Use caution when using an air nozzle, as at high pressure, the fabric of the filter medium may tear making the filter unusable.
- Kevin STP
83 Spectre 750
- wireman
- Thank you received: 299
In my experiance thats how it feels riding without a helmet in the rain. :sick: :woohoo:
- jeffasaki
78 Z1R
78 KZ1000
76 KH500 gone
71 HS1B 90
81 GS 1100 gone
80 PE400
02 KLR
Ontario Canada
- mark1122
- Keep twisting it
- Thank you received: 109
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- kzcurt
wireman wrote: Find a shop that does sand blasting and stand there next to the guy doing it out back without a hood or coat on,building up your tolerance as you go!
or like ridin behind a truck after fresh chip seal has been put down on the road!! :woohoo:
Flag carrier #23
9 @ 50-2053,
