- Thank you received: 36
The perfect engine - what is it?
- faffi
The perfect engine for me has instant throttle response from idle, is flexible and offer instant go the moment I open the throttle without having to change down a gear or more to get power. No dull throttle respones, no point in the rev range when power comes in, no fuzziness. All this while feeling relaxed on the road; low rpm and not too many cylinders. A big twin with stomp-pulling torque fitted into a standard machine with reasonable weight. A W 650, only with 1500 cc and 80 hp. And carbs. Nothing digital whatsoever on the bike save for the ignition.
What's your definition of the perfect engine?
1977 KZ650B1
1980 F1 engine
B1 3-phase alternator
B1 Points ignition
- bluej58
- Thank you received: 511
78 KZ1000 A2A
- 77street
- mark1122
- Keep twisting it
- Thank you received: 109
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- DoubleDub
- Visitor
- elfmagic17
- Thank you received: 24
Kenny Hicks
74 Honda CB550
- steell
- ready2ryde1985
- got to love these kzs
- Thank you received: 4
RS 34s
720 wiseco kit
cavanah heads
550 6 speed back cut
ape extra clutch disc kit
kerker black
ape block off plates
I would just want a crisp feel nice and tight when I pull or let off the throttle I want it to respond. No down shifting to find power just twist the grip and hold on. I would want it to be capeable of idol for days !!!
Mabe I should just find a good tuner to help me line mine out its close to perfection just seem to be a little off no matter what I do.
84 kz 700 a1
82 kz550 ltd
- Juan1
A compact, lightweight 650cc engine with Vtec that creates very little vibration. CAM 1 would provide good torque like a weeStrom or Versys, while providing mpgs like those bikes. Cam 2 would kick in at 6,500 RPM and provide a high RPM kick like my old 2007 FZ6. Most importantly, the 6th gear would be an overdrive gear. I don't mind downshifting.
Most importantly, and here's the rub, it must be easy for me to work on.
- baldy110
- Thank you received: 512
- DoubleDub
- Visitor
baldy110 wrote: ZX14R
Yeah, basically. I just wish it didn't look like an ugly Busa. And that's saying something...
- RonKZ650
- Thank you received: 240
