Another one followed me home!
- ramtough_63
Re: Another one followed me home!
09 Apr 2012 22:14les holt wrote: New toy not fairing out well, guessing we killed the hard drive in the computer on the way home. It's only $2250 for new pc.I have a lot of part making to get in the green on this one. And to think I'm going to be moving again in a few months.
Les
oh wow! sorry to hear that that seriously blows!
1978 KZ1000 A2
Facebook Page
Free Range Custom Art
1982/83 750R/GPZ
1984 Goldwing 1200 Interstate
1982 Yamahopper QT50
Previous
2 79 HD sporty XLH
02 HD FLSTS Heritage
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
and various enduros dirtbikes minibikes...
Facebook Page
1982/83 750R/GPZ
Previous
2 79 HD sporty XLH
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
- Zedone
13 Apr 2012 07:38
Wow Les, great work! You sure got this bike together fast... any pics of the new seat on it? Thanks Doug
1977 KZ1000A1
1977 KZ1000A1 (Superbike Project)
1969 Chevrolet C/10 Short Fleet
- mark1122
- Keep twisting it
13 Apr 2012 09:50les holt wrote: Little updating needed. Got the seat in, it's okay but still not what I'm wanting, the fit isn't that bad but it could be better, I'll post a pic when I get the new camera in. Bumped the pilot jets up to 22.5 from 17.5 and changed out the air bleeds to .6 from 1.0's, BIG difference but still need to sync them. Hoping the new plug wires will be here by the week end but not important, it still runs. Going to be cooler here the next few days so I'm spending time in the shop, new toys there too.
Oh, and goo gone took the chain lube off like it was nothing.
Les
what carbs r u working on now? RS34's ?
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- les holt
13 Apr 2012 15:53
Here are some pics with the seat on. I'm not happy with the fit over the tail but otherwise not bad.
I've got the airfilters off cleaning and reoiling, I didn't have a filter on the crankcase breather, made a couple hard passes and they had a little motor oil on them.
As for the carbs, I went with the 33 smooths. I've run the RS34's on other bikes and still prefer the 33 smooths. They are a bear to tune but I think they run better. I had never tried the .6 air bleeds till now and they do seem to help but the bog is mildly still there but common sense fixes that. Idle is a little rough but not so bad it's a problem.
Les
Attachment picofseat2.jpg not found
Attachment picofseat1.jpg not found
Les
76 kz 900 turbo
77 LTD 1000 turbo
2 78 Z1R's
72 H2
76 kz 900 turbo
77 LTD 1000 turbo
2 78 Z1R's
72 H2
- ramtough_63
13 Apr 2012 15:58
I will get a piece of that closed cell foam and send you. should be able to mould it around the bottom reinstall your cover and close the gap without being able to see it. be monday before I can get back by there. I am going to redo mine monday or tuesday
1978 KZ1000 A2
Facebook Page
1982/83 750R/GPZ
Previous
2 79 HD sporty XLH
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
Facebook Page
1982/83 750R/GPZ
Previous
2 79 HD sporty XLH
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
- Zedone
13 Apr 2012 16:16
Yes I see what you mean @ the rear of the seat. Are the seat bracket bolt holes slotted, I wonder if you could tweek it a bit to line it up better or lengthen the bracket holes Les. It also looks sorta wrinkled where the driver sits, maybe it will tighten up later on. Still is the nicest looking seat on the market IMO.
1977 KZ1000A1
- les holt
13 Apr 2012 16:31
The wrinkle may be from the rake on the frame. Guy out of Indy done this some years ago, cuts a section out of the backbone, pulls the neck back then cuts the tank mounts off and moves them back to clear the front end like original so the seat is pretty tight with the tank being slid back some. I really never checked to see if the holes were slotted but I did have to brake one loose to get it mounted and really didn't notice too much play to suspect slotted holes. I was going to get another seat recovered to simulate this one but fix the gap but right now my extra time is in the shop working. As for comfort I really like it, it's fairly firm which I like and fits me pretty good. I'm 5'10 about 180 so pretty much should fit an average build person.
Les
Les
76 kz 900 turbo
77 LTD 1000 turbo
2 78 Z1R's
72 H2
76 kz 900 turbo
77 LTD 1000 turbo
2 78 Z1R's
72 H2
- ramtough_63
13 Apr 2012 17:15
those wrinkles should disappear once it sits in the sun a couple hours. we used to use a steamer when I had my shop and steam em you could watch the wrinkles disappear about the only wrinkles that wont go away are on a cover that is too loose or pulled or sewn wrong those will go away no problem.
1978 KZ1000 A2
Facebook Page
1982/83 750R/GPZ
Previous
2 79 HD sporty XLH
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
Facebook Page
1982/83 750R/GPZ
Previous
2 79 HD sporty XLH
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
- Zedone
14 Apr 2012 05:16
Ok I get ya. Thanks for posting that Les. I was thinking the same thing about using heat to fix wrinkles Ram... I remember reading that some time ago on another forum.
1977 KZ1000A1
- mark1122
- Keep twisting it
14 Apr 2012 08:51
i has the vm33's as my last carbs. i liked them too. i like the rs34's that i have now better though.
what about putting the new foam and skin on an original pan?
OMR had to move his seat back after moving the tank back for mor neck clearance.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- les holt
14 Apr 2012 15:44
That was my plan Mark, I was going to take 2 seats I have and this one to copy and have them fix the fit around the tail but with the bike running it's hard to let this one go. I may just take one other and this one to get modified so I can still ride.
I think the 33's pull harder all the way thru and possibly idle better when you finally get them set. I would like to try a set of cr33's and may do so later.
Les
Les
76 kz 900 turbo
77 LTD 1000 turbo
2 78 Z1R's
72 H2
76 kz 900 turbo
77 LTD 1000 turbo
2 78 Z1R's
72 H2
- les holt
19 Apr 2012 19:38
Well I'm holding off on the seats for now and going to ride as is. Only thing left is license plate holder but it's done, just not mounted. Thought I'd wait till after giving it a bath.
Just to say, I'm pleased, I do wish I had stretched it another 2 inches but it looks pretty good as is.
Les
Attachment justwashed3.jpg not found
Attachment justwashed5.jpg not found
Attachment justwashed7.jpg not found
Les
76 kz 900 turbo
77 LTD 1000 turbo
2 78 Z1R's
72 H2
76 kz 900 turbo
77 LTD 1000 turbo
2 78 Z1R's
72 H2
