- Thank you received: 299
bolts
- wireman
good ol grade 2 steel bolts 60-74,000 psi/bottem of the barrel stainless steel bolts
80-90,000 psi.
even the lowest grade stainless bolt is 1 1/2 stronger than the frame its attached to.
- andy9802gt
- If it tastes that good, eat it yourself.
- Thank you received: 18
'78 KZ1075 LTD
stage 1 head by Larry Cavanaugh
race built crank by John Pearson
Mikuni rs34's
k410 cams
back cut tranny
8" over D&G swinger
proving once again that age and treachery is better than youth and enthusiasm
- TeK9iNe
- What did you do!?!
- Thank you received: 28
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- andy9802gt
T_Dub wrote: Any M8 bolt will snap off with a 3/8 ratchet, doesn't matter what you have. Tensile strength is one thing, but as soon as you start twisting it you go into a torque regime, and the stress induced by torque is magnitudes higher than an axial force, which the bolt is designed for. Thats why bolts have a toque rating that might seem low, but in the case of something like engine bolts, they are usually designed to go up to 90% of the proof strength when torqued, thats why sometimes when you overtorque it seems like the bolt snaps off really easy.
My APE cylinder studs are wet torqued to 22lbs-ft in the case and 42lbs-ft on the nuts, what's the factory studs torque specs? Hers a hint, less than the APE fasteners.
'78 KZ1075 LTD
Mikuni rs34's
k410 cams
back cut tranny
8" over D&G swinger
- andy9802gt
'78 KZ1075 LTD
Mikuni rs34's
k410 cams
back cut tranny
8" over D&G swinger
- T_Dub
- Thank you received: 25
Thereby proving my point. The APE ones are stronger, therefore they can take more load, which is their purpose. They are designed to separate at a higher cylinder pressure made by higher power machines. Thats why I have them in my bike.
BTW, my posts aren't opinions.
1977 KZ650B1
-810cc
-Cavanaugh Racing Head
-Mikuni RS34's
-GPR Muffler
- T_Dub
wireman wrote: ok heres your apples to apples comparison.
80-90,000 psi.
I'm not saying the stainless wont work. Nowhere did I say that. I just tried to explain a bit about bolted joint design. If you have a stainless bolt that will take the torque that the stock one will, then go for it. Stainless has other problems, such as if you have a stainless nut it will most likely gall. I think what Josh is getting at is that materials selection for important fasteners has to have more thought behind it than "oh its strong enough, it'll be fine". There are toher factors to consider when making a materials choice.
As for apples to oranges, you are comparing that when you go around saying things like the bolt is stronger than the frame it is attached to. The frame isn't a bolt and the bolt isn't a frame. Sure, from a bulk materials property perspective, the bolt is stronger, but these are mechanical components, not bulk materials. They have different loads, and different purposes in the assembly.
That all said, I hope you all have coatings on whatever aluminum you have fastened with your stainless bolts, cause it'll stain the bejesus out of it. I wouldn't put stainless on a bike either without looking into the corrosion cell its setting up.
1977 KZ650B1
-810cc
-Mikuni RS34's
-GPR Muffler
- wireman
- andy9802gt
'78 KZ1075 LTD
Mikuni rs34's
k410 cams
back cut tranny
8" over D&G swinger
- les holt
- Thank you received: 288
- wireman
- Stu Pidasole
- if you aint mod'n, you aint rock'n!
