- Thank you received: 18
bolts
- Kawickrice
73 Kawasaki Z1
07 HD CVO Ultra Classic
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
79 RD 400 Daytona Special
72 Honda CL 175
74 Honda QA 50
Tampa FL
- testarossa
- Thank you received: 82
2004 ZX-10R
2007 Harley Sportster 1200
Angola, IN
- T_Dub
- Thank you received: 25
1977 KZ650B1
-810cc
-Cavanaugh Racing Head
-Mikuni RS34's
-GPR Muffler
- Thank you received: 2829
- T_Dub
There are generally two categories of bolted joints. One where the joint is being pulled apart in the axis of the bolt(axial), and one where you are pulling the two parts of the joint apart perpendicular to the bolt. In both these scenarios the tensile strength is important, as you will tighten the bolt to a certain percentage of the bolt's "proof strength" which is itself a percentage of the tensile strength.
In the axial case you design a joint so that the load in the bolt compresses the joint to the point where the joint load will not separate the two halves.
In the perpendicular case, the tension in the bolt causes friction between the two joint surfaces. This is what prevents the joint from being pulled apart. Most people think it is the shear strength of the bolt which keeps it together, but in a properly designed joint of this type the applied force will never overcome the friction force between the surfaces that the joint creates.
I hope that was clear enough.
1977 KZ650B1
-810cc
-Mikuni RS34's
-GPR Muffler
- T_Dub
1977 KZ650B1
-810cc
-Mikuni RS34's
-GPR Muffler
- trianglelaguna
- Thank you received: 235
for what that is worth
as far as selling sats of motor mounta or brace kits for that matter...even when just seeing if folks would be game for said products...it imo helps greatly to have said items displayed on a bike or a mock up so folks can gauge their interst level...i think if someone were to put a few sets on display it would generate a GREAT deal of interest
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
- T_Dub
1977 KZ650B1
-810cc
-Mikuni RS34's
-GPR Muffler
- wireman
- Thank you received: 299
they also have regular grade 5 rated stainless steel bolts which are still over rated compared to rest of materials/fasteners on the bike.testarossa wrote: Ok, are you going to have ARP make your mount bolts using their special alloy stainless? If not then regular 304 ss is more like 75,000psi and 316 ss is closer to 84,000psi. Both less than grade 5 fasteners. Aside from that, you cannot compare the tensile strength of a fastener to a mild steel frame. They experience different types of loads. Yes the bolts are in tension, so tensile strength is an apt measure of their performance. However, the frame is not simply in tension. Tensile strength is not the only qualification for material selection. Heck, bamboo can have a tensile strength approaching 72,000psi, should we make our bolts from bamboo? It's an apples to oranges comparison. Different materials fit different applications. In my opinion, yes, the ARP stainless bolts, if tested to 170,000psi are a superior fastener, but regular stainless is inferior to even grade 5 fasteners, and more expensive to manufacture.
would you weld the frame together with welding rod rated at 100,000 plus psi? :laugh:
apples to apples?everybody keeps talking about the lowest end of the stainless steel food chain like its the only bolt you can get,they make steel bolts that are lower than grade 5 also.
What grade do you think those studs on the bottem of fork leg caps are rated at?
heres a clue,theyre the same stud used for kz1000 exhuast studs and they snap off pretty easy with a 3/8 ratchet! :laugh:
- Old Man Rock
- Thank you received: 225
Damn, I guess my KZ is under rated on torques and such... whoa...
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
- trianglelaguna
one other thing that i have been thinking about on items such as exposed motor mounts(trick racer stuff/bling)oil cooler fittings,block off plates..ect....but lemme stick to exposed bolts/motor mounts...is that i am at the stage on my project where i am gonna have something pretty close to "special" imo...as well as many others here who already have their build completed or say some of the builds close now on the forums.....
and being that the main design/themes are already close....the little things like porsches steering nut or the like need to be of the kind of quality and finish that they will be able to stand the test of time on the project...sounds simple but already some items that were once trick have begun to fade or discolor.....
my goal if i spend 300-400 to mount a trick earls oil cooler and fittings ,is to have the execution at the top level...ie ...like the race teams turn out stuff, super tight and sano and not tie wired on ...not a second rate finish or in a year have it start to fade or rust....
what good is a trick aluminum motor mount triangle if the heads of the fasteners only stay nice a season or two...or what good are block off plates if the bolt heads rust...makes the whole thing look crappy....
aim super high on the stuff imo..it cant be too good...price on these items really is set by the final bottom line of what makes the cut imo
1976 KZ900
2003 ZX12R
2007 FZ1000
- T_Dub
Any M8 bolt will snap off with a 3/8 ratchet, doesn't matter what you have. Tensile strength is one thing, but as soon as you start twisting it you go into a torque regime, and the stress induced by torque is magnitudes higher than an axial force, which the bolt is designed for. Thats why bolts have a toque rating that might seem low, but in the case of something like engine bolts, they are usually designed to go up to 90% of the proof strength when torqued, thats why sometimes when you overtorque it seems like the bolt snaps off really easy.
1977 KZ650B1
-810cc
-Mikuni RS34's
-GPR Muffler
