- Thank you received: 104
1/4 mile times.
- PLUMMEN
well the first 60 years did wonders for you ,we're waiting on the results of the 2nd 60! :woohoo:All guessing aside, it's the first 60' that's going to prove who's guess is best :laugh:
- donthekawguy
- Thank you received: 8
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1965 Suzuki Hillbilly
1964 Yamaha 125
- Thank you received: 2098
...marketing director for "OTTO-TIVES" auto/cycle products (TM) ne div,im also a customer! :laugh:
The P
- PLUMMEN
- CoreyClough
- GPz550 Addiction
- Thank you received: 80
A friend of mind had an all stock '84 GPz550, and ran in in NH Night Drags, consistantly at 12.70/104 mph.
I agree, take it to the track as it is, and learn how to launch, then make it go faster.
'85 GPz550(ZX550-A2)
- larrycavan
- Visitor
when all else fails a rack of bs34s and the coil mod is good for atleast 50mph on the big end .
combine that with the kz1k frame mod which should be good for another .10 off your time if youre pushing it down the the track,.05 if you weld everything back together first and ride it! :woohoo:
I'm calling bullshit on this one :laugh: You know full well that coil-mod / BS34 setup only works with a Mac pipe... quit teasing the guy
- PLUMMEN
not everybody has access to all the fancy stuff at calf-n-aw racings skunk works dept! :woohoo: Larrys high school picture :woohoo:
- larrycavan
- Visitor
:laugh:
- 9am53
- homebrew, and some bbq
- Thank you received: 3
'84 GPz900r
'71 CB350
s289.photobucket.com/albums/ll231/9am53/
- big mike
- PLUMMEN
beadlocks are pain in the ass! :laugh:
- Thank you received: 2829
DoubleDub wrote:
Through rim into tire bead on both sides, helps keep tire from slipping on rim. Some use more than others. Try to evenly space to keep "balanced" around the rim.Screws in the rim?
I had to do this with my BSA after ripping the valve stem out of the tube hitting second gear (thrill ride, I assure you!). Didn't know about rim locks or they weren't invented yet in the olden days. The screws solved the problem. Not necessary with tubeless tires. Ed
