1/4 mile times.
- hocbj23
- Visitor
- suzukikid62
- gearheadmm
- MUCH MORE BOOST..........I mean BRAVO
- Thank you received: 11
General Joeseph Dunford FOR PRESIDENT!!!
69.46.28.106/forum/11-projects/413221-80-kz-1000-st-recycled
- PLUMMEN
- Thank you received: 104
in that thin stuff you guys try to pass off as air im amazed anything runs! :laugh:You're got going to run 11s unless you are Pee Wee Gleason. My guess is a good running KZ1000 relatively stock with a 175lb rider you may break into the 12s barrier, but barely. 12.80-90 would be my guess. I'd be surprised if it was faster than that. With lower gearing you may get to 12.50
- grumpy56
- Thank you received: 6
Lewis
1982 KZ1000-J2
2006 HD FXD35
1970 Suzuki T350
1972 Suzuki GT380 (In-Process)
In The Past...71 TM400, 72 H-D SS350, 72 GT380, 75 Z1B, 77 XLH, 79 CB750K
- PLUMMEN
- DoubleDub
- Visitor
- Thank you received: 2098
Through rim into tire bead on both sides, helps keep tire from slipping on rim. Some use more than others. Try to evenly space to keep "balanced" around the rim.Screws in the rim?
- larrycavan
- Visitor
- PLUMMEN
combine that with the kz1k frame mod which should be good for another .10 off your time if youre pushing it down the the track,.05 if you weld everything back together first and ride it! :woohoo:
- Old Man Rock
- Thank you received: 225
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
- PLUMMEN
Im not just the marketing director for "OTTO-TIVES" auto/cycle products (TM)ne div,im also a customer! :laugh:
