1/4 mile times.
18 Feb 2011 19:26 #431666 by suzukikid62
1/4 mile times. was created by suzukikid62
Hey I have a few questions I'm hoping I can get some answers. I have a 1978 kz 1000 its lowered and it has a vance and hines pro side winder with stock carbs and gearing. I was wondering what kinda 1/4 mile times I could get with it tunes perfect? What gearing should I have for 1/4 mile? I weigh about 175. I took off about 30lbs of chrome and other little things not need. What is the fastest it could run with a very good rider on it? Thank you
18 Feb 2011 19:34 - 18 Feb 2011 19:35 #431668 by Kraz1
Replied by Kraz1 on topic 1/4 mile times.
Between 11.3 & 11.8 @ 111 to 115 mph depending on gearing
Last edit: 18 Feb 2011 19:35 by Kraz1.
18 Feb 2011 19:40 #431669 by PLUMMEN
Replied by PLUMMEN on topic 1/4 mile times.
depends on what part of country youre in and condition of track also B)
18 Feb 2011 19:40 #431670 by suzukikid62
Replied by suzukikid62 on topic 1/4 mile times.
What gearing should put me close to those numbers
18 Feb 2011 19:42 #431672 by suzukikid62
I'm in indiana ill be running tracks like martin 131. Indy. Stanton. Norwalk. Rockingham. Very nice and sticky tracks.
18 Feb 2011 19:49 #431673 by Kraz1
15-38 at 33 to 178 ft above Sea-Level.
> Pick Your Track
18 Feb 2011 19:50 #431674 by PLUMMEN
what size tire/wheel?
i run 16/40(530) gearing on my 1327 with stock chassis and 3" over swingarm as low as i can get it with old kerker header my best time last season was a 6.18 114-115 at our little 1/8 mile track with no bar and my 205lb fat ass hanging over the bars trying to hold it down for first 100' slipping the clutch. B)
19 Feb 2011 08:14 #431751 by RonKZ650
Replied by RonKZ650 on topic 1/4 mile times.
You're got going to run 11s unless you are Pee Wee Gleason. My guess is a good running KZ1000 relatively stock with a 175lb rider you may break into the 12s barrier, but barely. 12.80-90 would be my guess. I'd be surprised if it was faster than that. With lower gearing you may get to 12.50
  • kzz1p
  • One Test Is Worth A Thousand Expert Opinions!
19 Feb 2011 09:46 - 19 Feb 2011 09:47 #431757 by kzz1p
Replied by kzz1p on topic 1/4 mile times.
Tell us more about the bike. Is it completely stock, other then the pipe? The biggest question, what skill level, rider are we talking about?
Last edit: 19 Feb 2011 09:47 by kzz1p.
19 Feb 2011 11:32 #431809 by suzukikid62
Its stock except the header and its lowered it has struts on the rear. Its got k&n air filters. It has the 18 in spoke wheerl on the rear and 19 inch spoke wheel on the front. Its stock gearing now but I plan to change it. And pretty exsperienced rider. I'm also wondering the time differences the an inexsperienced rider might run on the same bike
  • Stu Pidasole
  • if you aint mod'n, you aint rock'n!
19 Feb 2011 11:39 #431813 by Stu Pidasole
Replied by Stu Pidasole on topic 1/4 mile times.
i have an idea.....bring it to the track and post your et.
19 Feb 2011 11:43 #431815 by big mike
Replied by big mike on topic 1/4 mile times.
i had a 1000 and it was all stock payed 200 bucks for it it would run 11.40 at seattle as for gearing i would run 15 40 41 i go up to 43 44 in vagas and montana (630 chain)and i only run the motor up to 10.5 11.0 max rpm
