Best way to cross reference parts
- gte105u
26 May 2010 12:14 - 26 May 2010 12:15
I am curious what others do to cross reference parts. My first bike I did not do to much work on. My second bike was a Ninja 650R when they first came out, so there was nothing to "reference" to... everything was modded to work just about. Now I have an '81 KZ550, and am curious what parts that work on other bikes (LTD vs. standard, different models, years, etc.) will work on this. I need a center stand, seat lock, thinking of installing a chain guard back, etc. Do you find the part number you are looking for, and then do a search on BikeBandits.com to see if it pops up for other models? Is there a way to search on Kawasaki by part number? Is there a site/wiki that shows swappable parts (I saw something like this on the EX500 and interchangeable parts between generation 1 and 2). Thanks guys, hope this has not been covered too much before.
1981 KZ550 A2
Last edit: 26 May 2010 12:15 by gte105u.
- Zthou1977
Re: Best way to cross reference parts
26 May 2010 16:40
On the Kawasaki website are parts diagrams (owner info ->parts diagrams). After selecting the appropriate info, a pop-up window opens. At the top-center of the window is a drop-down menu that says 'model'. Find the part number you need, then select 'part number' from this menu and fill in the part no. You then get a list of all the bikes that use this particular part.
1977 Z1000A1, 1982-1986 KZ1000P (built from two piles of parts), Moto Martin Z1200 (trying to get it registered), 1977 Z650B1
Utrecht, The Netherlands
- JakeB
26 May 2010 16:51
Also on Kawasaki.com when you're searching the parts diagrams for your bike; if you click on a part number it brings up a window showing more info on the part, status etc. There is a yellow circle at the top with a question mark inside, click that and it brings up a list of everything that part was used on.
Zthou's method is similar, but this way skips the need for a second search for the part number.
1978 Z1-R
26 May 2010 18:55
Keep in mind that Kawasaki will assign a different part number to virtually identical part with only a color change for example.
- H1Vindicator
Last edit: 20 Feb 2013 20:24 by H1Vindicator.
- gte105u
27 May 2010 06:49
Great information guys. I already had the parts diagram bookmarked for my bike. I also already was clicking around. It was the yellow "?" that I did not know about... that works great. Thanks
1981 KZ550 A2
- OldSchoolHr
- Kawasaki z900a4 1976 Croatia, Europe
27 May 2010 07:19
I have bought Kawasaki cross reference program from Zedder for $24.95 and its very simple to use. You put part number and program list all models that use that part.
www.zedder.com/msg6.htm
My Gallery -
www.wix.com/limit2/z900
- gte105u
27 May 2010 08:27
Interesting program, but it sounds like this does for $25 what the Kawasaki program does for free. Is there anything it does you cannot get from the website?
1981 KZ550 A2
- Jeff.Saunders
27 May 2010 10:41
OldSchoolHr wrote:
If it listed the correct parts, the software would be wonderful...
However, Zedders software has several major problems. In the situations where multiple models are described on one fiche, entering a part number may show totally wrong fitment. Where there are footnotes on the fiche, zedder doesn't have that info. Where part numbers are superseded it doesn't handle this.
I have zedders xref for Kawasaki and Suzuki and just stopped using it - it is very poor. And as a previous poster pointed out - why pay $25 for something that's free (and better) on Kawasaki.com
The Kawasaki.com system is better, but sadly Kawasaki has deleted a large number of discontinued parts from the online fiche.
We are finding we are having to reference the old style fiche for more and more research these days.
www.z1enterprises.com
Z1 Ent on Facebook,
- H1Vindicator
Last edit: 21 Feb 2013 01:58 by H1Vindicator.
- OldSchoolHr
31 May 2010 11:35
gte105u wrote:
Just easier and faster, if I am suspicious about something I check on other places. For purpose I use it I had no problems yet.
My Gallery -
- trianglelaguna
14 Oct 2010 09:01
bump...i'm told that the 1982 kz-750 standard four is the same tail piece as the MKII chain drives.....but i am aware that a different paint color may be giving me the slip on nailing down a match.....
these are things i've been curious about...maybe folks here have tried one or more or know an answer,,,
i will fiddle with the kawi site more and see..i dig it and am getting some good ideas already thanks...
anyone know about these items::::::
1979-80 KZ1000 MKII (mine is an A3)
does it share it's tail cowling with the kz750 of 82?
can i use the right switch housing froman earlier kz1000-900 with the on/off headlight switch?
can i use the seat from any other kawi..1980 Z1R...shaft drive MKII....ect
1984 GPZ550 Ca model..(ZX550A1L)....
will the tank of the same design gpz 750 fit on the bike...i heard it may but i doubt this....they are super hard to locate...
thanks guys...any info would be cool
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
2003 ZX12R
2007 FZ1000
