Best way to cross reference parts
- trianglelaguna
Re: Best way to cross reference parts
14 Oct 2010 18:20
BUMP
anyone have any knowledge on these few parts
anyone know about these items::::::
1979-80 KZ1000 MKII (mine is an A3)
does it share it's tail cowling with the kz750 of 82?
can i use the right switch housing from the earlier kz1000-900 with the on/off headlight switch?for my 79 mkII
can i use the seat from any other kawi..1980 Z1R...shaft drive MKII....ect on my MKII a3
1984 GPZ550 Ca model..(ZX550A1L)....
will the tank of the same design yrs gpz 750 fit on the zx550 bike...i heard it may but i doubt this....they are super hard to locate...
thanks guys...any info would be cool
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
2003 ZX12R
2007 FZ1000
- trianglelaguna
15 Oct 2010 05:31
last Bump...anyone...know about those few parts if they swap...thanks again...
1976 KZ900
2003 ZX12R
2007 FZ1000
2003 ZX12R
2007 FZ1000
- Kidkawie
- I bleed premix
15 Oct 2010 07:25 - 15 Oct 2010 07:29
Patton wrote:
Yes!
I've noticed that some parts are superceeding to newer part numbers in lieu of those differences. For instance, a radiator for my 94 KX is NLA, but a rad for a 99-02 is still available. The only differences between the two is the 94 is black and does not have a tab for a small 2" brace. Originally 2 different part numbers. So somehow Kawi is making it a little easier for us.
Tri, another trick to this whole part interchange thing is to reserarch surrounding parts. Let's say....an intake boot (Holder, Carburetor) if the heads and carbs between the two bikes are the same part number then you can almost bet the holders are the same. Might have a vac port on the opposite side, but will bolt right in. Looking up gasket part numbers is a big help too.
Here's Patton's thread, it should really be a Sticky.
kzrider.com/index.php?option=com_kunena&...w&catid=13&id=376734
Keep in mind that Kawasaki will assign a different part number to virtually identical part with only a color change for example.
Yes!
1975 Z1 900
1994 KX250 Supermoto
2004 KX125
2004 KX125
Last edit: 15 Oct 2010 07:29 by Kidkawie.
- trianglelaguna
15 Oct 2010 09:02
ok thanks that is a good tip for the mounts and mating areas...great tip...
i need to mess around on the site there and see if i can get a tad better at it's quirks...thanks...
and thanks for pattons thread link...he has helped me so many times....awesome...and thanks patton...
1976 KZ900
2003 ZX12R
2007 FZ1000
2003 ZX12R
2007 FZ1000
