- Thank you received: 316
MAC Exhaust
- Mcdroid
- Gone Kwackers
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
- riverroad
- 1980 1000LTD B4
- Thank you received: 7
Decibel level seemed to be about the same, but my Mac had a deeper tone than his V&H. Almost made my engine sound bigger than his.
- loudhvx
- Thank you received: 1616
I will probably remove the Mac canister (All steel and heavy) and slip on a kerker or some other aluminum canister.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
- 9am53
- homebrew, and some bbq
'84 GPz900r
'71 CB350
s289.photobucket.com/albums/ll231/9am53/
- Mcdroid
- Gone Kwackers
are all kerker cans aluminum?
The K series are aluminum...the original style are steel.
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
- otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
- sbc1320
- Thank you received: 38
1980 KZ1000 LTD-B4(MK II engine) - Progressive suspension, MTC pistons, Dynojet Stage III, all wear items replaced, WFO paint scheme(1978), etc..
Past bikes- 2 1976 Kz900's, 5 1975-76 Honda CB750's, Honda 500 -4, Honda 250, Honda 125, Honda 100, Suzuki RM 250, Honda XL350, Kawasaki KLR 650, etc..
- otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- Galactica
- Thank you received: 2
I don't, and neither do my neighbours, like loud motorcycles. So I replaced them with MAC slip-ons. Really inexpensive. The chrome is already flaking off the leading edges (which happened on installation). But it sounds pretty good to me and I prefer the 4 into 2 look vs a 4 into 1 header. I'm not looking for more power. It has more than enough to get me into trouble.
The biggest issue for me is centre stand clearance. The 4 into 2 system pushes it down lower than the original 4 into 4, and I regularly scrape the stand on left hand curves.
Also for me to retain Collector Plate status I need to keep it as stock as possible, and 4 into 1 systems were not a stock configuration. I didn't look around all that hard, but MAC was all I could find in a 4 into 2 slip-on.
To sum up, I would buy them again. I may have to. Given the low price of $250 delivered, replacement every few years is no different than replacing a cheap muffler on a car every few years. It's just a cost of maintenance.
77KZ1000
76 KZ900
- JR
- Thank you received: 445
- otakar
When I bought my 76 kz900 it had the stock original head pipes. The four mufflers had been cut off and slip-on LTD pipes installed ( See pictures on July/August trip photos thread ). The insides were totally gone.
The 4-2 was not stock on the 900 either, so why would it make a difference for the plates since it is not the original 4-4. If it's not stock it is not stock, PERIOD.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- Galactica
When applying for Collector Plates you have to submit photos so they can do research and accept or reject your application. The photos I submitted showed 4 into 2 and was accepted.
The exceptions listed in ICBC's list of allowable modifications pertain to cars. The relevant ones are headers, a 4 barrel carb but not a hi-rise manifold, and period correct mag wheels. So I guess they deemed the 4 into 2 acceptable.
When dealing with our state owned insurance company, it's best not to press your luck. Especially when Collector insurance is only $230 for the whole year.
77KZ1000
76 KZ900
