Do you use any lock when you park?
  • tybolt99
  • Topic Author
  • From where KZs came
18 Oct 2009 17:53 #328299 by tybolt99
Do you use any lock when you park? was created by tybolt99
Hi everyone,
I was wondering how you park your bike. It may depend on where and when too. I don't even have steering lock cylinder on KZ900. Just pull ignition key out and walk away for now. Of course I don't park overnight or at no activity area anyway. thinking to get cable or disc lock in case I need.
Do you use any external locking devise?
82 KZ750 H3
76 KZ900 A4
74 Z1A
73 Z1 (on the shelf)
84 ZN1300
Franklinton, NC
18 Oct 2009 17:59 #328304 by racer54
Replied by racer54 on topic Do you use any lock when you park?
Fact is...if a thief wants your bike, they can get it. Bad thing about bikes is they can be thrown into the back of a truck by a few guys fairly easy. All you can do is keep other not so dedicated would-be thiefs at bay. I use a padlock put through one of the holes in the disc. Will move a little but will keep most thiefs away once they try to move it. Hardened lock best and if you use cable spend the money and get a good one. Any lock is better then none and park it where you can see it if possible.
  • trianglelaguna
18 Oct 2009 19:25 #328319 by trianglelaguna
Replied by trianglelaguna on topic Do you use any lock when you park?
boy that's a hard call...if you think you may need a lock...you probably do.....everywheres different......a disk lock or like racer54 said a padlock......
maybe start a thread or search a thread about putting a steering lock back in the frames neck.....
i on occasion lock my steering because of the vibes i get when parking around some folks.....more to make sure no one sits on bike and turns my bars and tips it over...ect.....or rolls it away......
some folks use a big link-two foot-chain and a big lock...gotta be a drag to carry around...good luck
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
18 Oct 2009 19:32 #328322 by PLUMMEN
Replied by PLUMMEN on topic Do you use any lock when you park?
a kill switch mounted in place of clutch safety switch helps slow them down even if they have a key they cant start it without knowing where switch is B)
  • tybolt99
  • Topic Author
19 Oct 2009 06:10 #328365 by tybolt99
Replied by tybolt99 on topic Do you use any lock when you park?
I may need to get a steering lock cylinder to start with. Then maybe a pad lock??
Kill switch might be good thing since there are not many combination of keys for these old bikes.
I know thieves can get it anyway if they want to. I had a car stolen from my driveway long time ago. It was parked 20 feet away from my roommate's bed room window:blink:
82 KZ750 H3
76 KZ900 A4
74 Z1A
84 ZN1300
Franklinton, NC
19 Oct 2009 06:19 #328371 by Bluemeanie
Replied by Bluemeanie on topic Do you use any lock when you park?
I park in my garage but just to make (thieves like big shiny things) sure, I installe pad lock thru holes in disc BEFORE I ever walk into house! If I'm going somewhere that bothers me I will bring pad lock along.
19 Oct 2009 06:31 - 19 Oct 2009 06:49 #328373 by rstnick
Replied by rstnick on topic Do you use any lock when you park?
I use a large Kryptonite lock that's designed for motorcycles. It fits through the front wheel on either side of the fork tubes.
I use to run it through the seat strap and right side grab rail when I took it with me.
You may be able to see it next to the seat in this pic:
I mainly use it at home now.
I do carry a disk/rotor lock with me now adays, but haven't used it in years.
It depends on where I park etc.
Rob
CANADA
1978 KZ650 C2, 130K kms, Delkevic ex, EI, CVK32, PMC easy clutch, ATK fork brace, steering damper, braced swingarm, 18" Z1R front wheel.
2000 ZRX1100
2011 Ninja 250R
2005 z750s
Last edit: 19 Oct 2009 06:49 by rstnick.
  • tybolt99
  • Topic Author
19 Oct 2009 06:35 #328375 by tybolt99
The only thing is I don't have drilled holes on the disc so I need to get something longer reach if I want to get a pad lock for disc.
82 KZ750 H3
76 KZ900 A4
74 Z1A
84 ZN1300
Franklinton, NC
19 Oct 2009 06:44 #328377 by Old Man Rock
Replied by Old Man Rock on topic Do you use any lock when you park?
I use a front disk brake lock but in your case.... Get one of those 2-3' long non cut-table cables and hefty pad lock where you can run it through the rear rim spokes around a frame tube and be done with it...
Down fall, big & bulky to carry around but hey... beats a stolen KZ right! ;)
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
  • tybolt99
  • Topic Author
19 Oct 2009 07:20 #328382 by tybolt99
I kinda wanted be done with a pad lock. Oh well.
I think I may be able to find room under the seat since I don't have air box.
82 KZ750 H3
76 KZ900 A4
74 Z1A
84 ZN1300
Franklinton, NC
  • tybolt99
  • Topic Author
19 Oct 2009 07:24 #328384 by tybolt99
I see it. The only thing is to carry it in my case. I need find the way other then you have.
82 KZ750 H3
76 KZ900 A4
74 Z1A
84 ZN1300
Franklinton, NC
19 Oct 2009 07:43 #328385 by Sandy
Replied by Sandy on topic Do you use any lock when you park?
A Scorpion Alarm system works great.
It even has a ground sensor that will protect any luggage attached to the bike.
2-way transmitter alerts you if your alarm has gone off.
Not cheap,but so worth it. B)
www.scorpioalarms.com/products/motorcycle/sr-i500_trs6/
1977 KZ1000 A-1
