- Thank you received: 12
Sea Foam question
- WPBill
www.seafoamsales.com/motor-treatment/pro...carbon-deposits.html
You can only be young once, but you can be immature forever!
Kamakura JAPAN, 1975 Z1B (x2, both in storage)
- riverroad
- 1980 1000LTD B4
- Thank you received: 7
Restore makes multiple products.Are you speaking of the one that is the very viscous "Motor Honey" Like STP oil treatment. If so, Than by NO means put that in your engine. Your compression will go up but the spring back on the rings will not be able to scrape it from the Cylinder walls and you will burn oil like crazy. This is why I use the Rislone "engine Treatment" and not the "Oil Treatment".That is also the extremely viscous engine honey. It will make your bike smoke like crazy and the clutch will slip.
The Restore stuff I used in that old Chevy was a little thinner STP, but it had some dark particulate matter in it (maybe graphite) that supposedly filled in scratches and closed up excessive clearances. At least that's what the commercials said anyway. But when I used it, it occured to me that this particulate matter was probably just clogging up my oil filter.
Funny thing about that old Chevy, it had so many miles on it, the timing chain actually stretched far enough to wear a hole through the timing cover. So I put another timing chain and cover on it, along with a set of reconditioned heads I bought for thirty bucks, and it ran great, for a while. Soon the rings couldn't handle the pressures the new heads were producing and it started burning oil REAL bad.
- otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
- Russ Jackson
1976 KZ 900 B1 29 smoothbores, Kerker, Lester Mags
2008 Kawasaki Concours 14 abs
- otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
