Pics 82 KZ1000 22 miles
04 Apr 2008 11:51 #204231 by kawisteve
Replied by kawisteve on topic Pics 82 KZ1000 22 miles
Thanks for the info and opinions so far. I do believe it is 22 miles and no apologies necessary, not a problem. The pics are not the best, but there is no wear or signs of use on anything. I did not pull the side covers as I was worried about breaking a tab or the rubber grommets, but everything, despite being covered in dust just appears unused and yes, stored incorrectly for sure. It will take some elbow grease for sure, no doubts. I do have more pics, mostly the same types of stuff and same quality. I did take them before the sun was even up this morning. If we did put a reserve, any ideas???? I know some of you may be interested, and we probably will not put a reserve at all, just curious as to what you think? By the way, no scoring on the Front Rotors, just the photo and it does have the Electronic Speedo. Thanks for all the help guys.
77 KZ1000 A1
77 KZ1000 B1 (Always need parts, right?)
68 A7SS Avenger (the project, but arnt they all!)
95 ZX6R
03 ZR1000 A1
04 Apr 2008 11:58 #204232 by Locozuna
Replied by Locozuna on topic Pics 82 KZ1000 22 miles
Was it put away wet? With all fluids(gas in tank, battery installed, full of oil)? It looks to me to be slightly more mileage but not much more. I would be bidding if I was closer and had another stall open. Could be a easy job or a nightmare to get it square but at least it is all there. It is very purty!:ohmy: I can't imagine opening up a barn and finding that sitting under 25 years of dust! They'd be giving me last rites and trying to get that silly smile off my face for the showing. :woohoo: Post the e-bay auction I want to watch it.
"Over the Mountains
Of the Moon,
Ride, boldly ride,"
The shade replied
"If you seek for Eldorado!"
04 Apr 2008 12:27 #204237 by kawisteve
I am not sure how wet it was. The tank looks clean inside with no fuel residue, but the throttle is stuck, gummed carbs. There is no battery, but it does have clean (26 year old, I guess) oil in the case. The front brake works, but you can see in the photos there was some fluid leakage at one time and I don't see any brake fluid in the site glass. Looks like someone had some kind of an idea of how to store it, but just didn't follow through. The tank is spotless on the inside. I will post a link when it does go on and we should have better photos as well.
77 KZ1000 A1
95 ZX6R
03 ZR1000 A1
04 Apr 2008 13:29 - 04 Apr 2008 13:30 #204251 by tw..
Replied by tw.. on topic Pics 82 KZ1000 22 miles
Just my 2 cents. and I'm not expert by far, but the tires look to have more than 22 miles on them. :unsure:
But it's still and excellent bike.
2-1976 KZ900 A4
1995 KZ1000 Police bike
1978 Z1R
Last edit: 04 Apr 2008 13:30 by tw...
04 Apr 2008 13:29 - 04 Apr 2008 13:32 #204252 by N0NB
Replied by N0NB on topic Pics 82 KZ1000 22 miles
That's simply an amazing find, Steve. If I had to sell it, I'm not sure I'd let it go for less than $1500. Call me crazy, you won't be the first. :woohoo:
As for the front brake, your detailed pic just shows the surface rust being polished a bit from the natural drag of the pads, IMO.
Aside from cleaning and maintenance to get things up to snuff, I can't imagine anything major being wrong with it. I would think that with the mileage shown that anything major would have been dealt with under warranty. If the speedo was changed out by the dealer, there would have to be paperwork to that effect unless it was lost over the years.
Maybe I'm a bit crazy, but I don't think I'd be scared of that bike.
Too bad it doesn't have a kicker so at least some idea of the compression could be determined.
Nate
1979 KZ650 (Complete!)
1979 KZ650 SR (Sold!)
1979 KL250 (For sale)
1994 Bayou 400 (four wheel peel :D )
Last edit: 04 Apr 2008 13:32 by N0NB.
04 Apr 2008 22:24 #204347 by Bad Kaw
Replied by Bad Kaw on topic Pics 82 KZ1000 22 miles
The 'wear' on the rotor is what a rotor with 22 miles on it would look like: just barely been touched by the pads a couple times.
The tires 'wear' is probably dirt/dust from setting for 26 years (Notice they are Bridgestone Mag Mopus...the WD40 of sport-bike tires from 'the day'; been there, crashed on that...ha!).
My larger concern would be what does oil turn into after it sets for 26 years? Chem majors? The new stuff breaks down into some kind of acidic stuff that isn't good on motors. That thing had oil that is from 1982...anyone out there know what the oil contents were back then? I doubt that zinc and any other phosphates were added back in the day...but it also could be a superior lubricating oil since the gov probably didn't have as restrictive laws in place for motor oils...I don't know.
Hmmmmmm...
78 Kawasaki Z1R
81 Kawasaki KZ1000J (mods)
70 Kawasaki KV75
83 Honda CB1100F (few mods)
05 Apr 2008 05:26 #204370 by steell
Replied by steell on topic Pics 82 KZ1000 22 miles
My $0.00002 :)
As is, non running, it will probably fetch $2000-$2500 on eBay.
Running, cleaned, and polished, maybe $5000-$7000 on eBay.
Just my wild guesses, because on eBay you never can tell, I have seen used spark plugs, worn out sprockets and chains, and even worn out clutch frictions, sell on eBay :woohoo:
05 Apr 2008 05:36 #204372 by Locozuna
We did a couple of old long sitting bike resurrections. The oil will be like sludge. Oil goo!:angry: Got to get it warm, drain, refill, repeat, repeat. We used Marvel Mystery oil to cut it a little and to weep the cylinders prior to moving the engine.. After about 4 or 5 oil changes we finally were getting out the same amount we put in and it was clean. But the bikes are still running years later with no sign of problems. Beats cracking it. $2-2.5 large I would have no prob paying. That is about it not running, all by eye!
"Over the Mountains
Of the Moon,
Ride, boldly ride,"
The shade replied
05 Apr 2008 07:11 - 05 Apr 2008 07:18 #204379 by RonKZ650
Replied by RonKZ650 on topic Pics 82 KZ1000 22 miles
All the engines I've seen that had oil sitting in them, regardless of how long they sat, the oil is just fine (to look at at least). It will drain right out and fill her up with new oil. 26 yr old oil won't be a problem. Salt Lake has the same general climate as we see in Denver which is dry so assuming the engine did not sit outside with the oil fill plug removed the oil should not be a problem. So arguably I'd bet if the bike actually has 22 miles on it, drain the oil, clean the carbs since it seems they had gas stored in them, put gas in, start right up with no leaks.
Last edit: 05 Apr 2008 07:18 by RonKZ650.
05 Apr 2008 08:04 #204394 by Locozuna
The resurections we performed were of a different nature. I'll give you that. One was a KZ650 that had sat in an aluminum shed for about 18 years here in the northeast. It had 15,000 mi on it. I knew the owner who did the recommended oil changes. That oil was the constituency of grease. At first drain about a quart drained and then by glops maybe another half quart. We put in the recommended amount of oil and started. Ran great for 1 minute and started rapping n' running like crap. Oil was coming out the breather vent. I thought we had seriously done in the engine. We knew what had happened and drained the oil and a whole lot of stinky crude ran out. That was the worse one. Two other bikes displayed some of the same problems. All of them were subject to some extreme heat and cold cycles and were higher mileage bikes for sure. Plus must have had more than 22 miles since fresh oil was put in. So maybe it was condensation or regular running contaminants that caused the oil to turn to tar but tar it was. Even that doesn't scare me since like I said a little patience and all three remain running the roads today.
"Over the Mountains
Of the Moon,
Ride, boldly ride,"
The shade replied
  • The Gringo
  • ¡Usted no necesita otra motocicleta!
05 Apr 2008 08:20 #204403 by The Gringo
Replied by The Gringo on topic Pics 82 KZ1000 22 miles
I have to concur with you guys as to the value estimate and the fact that I too wouldn’t be terribly afraid of the mechanical soundness of the bike. Most of us have brought much worse back to life. I would be more hesitant about tackling the cosmetics than the mechanics. I’ve always found it takes more work to make them look good than it does to make them run good. Maybe I’m just stingy with the elbow grease.
The fact that it comes with a color matched, in the box, genuine Kawasaki accessory, Vetter fairing is appealing to me as well. I’m probably in the minority here but I’d probably mount that sucker on that bike and enjoy riding the bike around. I rode a 78 1000 A-2 that had a Vetter for a while and I loved it. Nice to be able to ride down the road and smoke a cigarette at the same time.B)
Andy
Akron, Ohio
80 Z-1 Classic-Sold
84 GPZ1100
79 KZ 1000 LTD
78 KZ 1000 A2
77 KZ 1000 LTD-Sold
KZ 550 times 2 80 440LTD-Sold
05 Apr 2008 12:07 #204442 by kawisteve
Okay, sorry, I don't get on here as much as I would like, but finally got back to look over what you all have said. So...Now that you have looked at it, I will ask the original question again. Should we clean it up and get it running, not a problem, we have a shop, or as true Kawasaki fans, do you think it should be left alone. If the final outcome of cleaning it up first is going to bring in more $$$, then that is what will happen. If it was my bike, the money wouldn't matter, there would be no question, it would stay in my garage, but sadly it isn't mine and I am only trying to help my Uncle get the most he can out of it. I appreciate everything I have read so far, it has helped.
77 KZ1000 A1
95 ZX6R
03 ZR1000 A1
