What gas mileage do you get?
- 2M4Dale
BTW ... the old girl made 55 horsepower at the rear tire. And the pull was very smooth and even across the chart. The tech seemed impressed ??? Is this horsepower rating about right ? Owners manual says 74 horsepower ????
Hello from Sunny Mansfield, Ohio
1980 KZ750H1 LTD
1981 KZ750H2 LTD
- steell
Drivetrain losses seem to run around 20%, so 14.8 hp on your 74 hp 750, and that would put you at 59-60 hp.
Was the hp corrected for altitude?
- 2M4Dale
If the dyno horsepower rating is, indeed, low ... as in below expectations .... well I just don't care .... lol.
She's plenty fast enough for me !!!! And she runs good and smooth once warmed up. Albiet, she's cold blooded as hec !
1980 KZ750H1 LTD
1981 KZ750H2 LTD
- steell
There you go!
Dyno numbers (especially from the inertia dynos) are for bench racing, all that matters is if you are happy with it.
From a guy that rides a 750 twin rated at 54 hp at the crank by Kawasaki
But it's fast enough to be my daily rider, and fast enough to get my license suspended, if I was so inclined
And it's lot's faster than my pickup truck, while getting 84 mpg vs 12 mpg, at $3.95 per gallon that's pretty important to me.
- H2RICK
- Is this a fun bike, or what!!!
- Thank you received: 1
Dale, with Ohio being reasonably close to sea level AND your bike being a 1980 model, the cold bloodedness doesn't surprise me. 1980 was the watershed year for most Japanese bike manufacturers when the EPA stepped on their cojones and made them lean the fuelling out considerably. Low altitude and leaner carbs make for slow cranky warmups on most 1980 and later carburated bikes. Short of changing the pilot jets, you'll just have to live with things as they are.Albiet, she's cold blooded as hec !
KZ650C2 Stock/mint. Goes by "Ace".
H2A Built from a genuine basket case. Yes,it's a hot rod.
GT550A Stock/mint. Pleasant stroker.
2006 Bandit 1200S for easy LD rapid transit
Various H2 projects in the wings.
- 2M4Dale
Dang steel .... your 750 twin gets 84 mpg ???? I think I gotta get me one of those !!!
1980 KZ750H1 LTD
1981 KZ750H2 LTD
- N0NB
- Blue handles better
Nate
1979 KZ650 (Complete!)
1979 KZ650 SR (Sold!)
1979 KL250 (For sale)
1994 Bayou 400 (four wheel peel )
- steell
H2RICK, I'm gonna live with it this riding season .... maybe this upcoming winter I'll fiddle around with the carbs a bit.
Keep in mind that I was operating in economy mode the entire time, minimum throttle and shifting at 3k rpm, and 45/60 mph cruise, 60 on highway and 45 on County roads, and I spend more time on County roads.
And there's also the notoriously inaccurate speedometer/odometer to consider. My normal spirited riding style nets me 55-60 mpg on the 750 twin, I only started riding for economy when gas hit almost $4.00 per gallon.
- rstnick
- Thank you received: 377
I got 5.25 litres/100 km = 44.80 mpg.
This was on the return trip, mostly highway riding.
Kerker 4>1
K&N filter in stock airbox
Kawi elec. ign.
Rob
CANADA
1978 KZ650 C2, 130K kms, Delkevic ex, EI, CVK32, PMC easy clutch, ATK fork brace, steering damper, braced swingarm, 18" Z1R front wheel.
2000 ZRX1100
2011 Ninja 250R
2005 z750s
- ronjones
- Thank you received: 4
- Bluemeanie
- Thank you received: 14
- steell
Those 40-50 mph cruises on secondary rodes really boost the mileage don't they.I earlier posted that a mix of Interstate and secondary I got about 48mpg. I haven't remembered to recheck until Saturday. I filled the tank and went for an 87mi ride and refilled 1.266 gal when I got back. Mostly 40-50mph, up to 60, country secondary rds. If my calculator is correct that's almost 69mpg :huh::woohoo:
My motor is an 82 750 twin with 79 carbs, and I just did the valves, synched the carbs, adjusted the carbs, new plugs, Accel coil, electronic ignition, K&N stock replacement air filter, fresh oil change, stock 80 two into two exhaust, new chain and sprockets, wheel alignment, and 32 psi front, 30 psi rear on the tire pressures. So it's tuned perfectly right now and getting about the maximum mileage possible.
And I try to stay off the Highways and ride the secondary roads at 45 mph
