- Thank you received: 1
What gas mileage do you get?
- H2RICK
- Is this a fun bike, or what!!!
Examples from the chart for the D1A:
4000 RPM = 26BHP = 255g/HP-Hr = 6630g/Hr
7000 RPM = 55BHP = 210g/HP-Hr = 11,550g/Hr
In the above example at 7000RPM you are generating 2.12 times more power than you are at 4000RPM......BUT you are only using 1.74 times more fuel because of the greater efficiency of the engine at 7000RPM.
Unfortunately on most modern roads it is very difficult to ride at 4000 RPM at highway speeds without rowing on the gearbox lever continuously because you are 'wayyyy back down the torque curve. You are just not producing enough torque to move the bike and rider mass/frontal area against the rolling and wind resistance.
Around town, or on surface streets it is eminently feasible to ride at 4000 RPM in, say, third gear and you'll get excellent mileage....but this is also impractical because around town/on surface streets you are usually stopping and starting and that defeats the whole purpose of steady state 4000 RPM riding.
Sooooo....the ideal solution is to ride on secondary roads with no stop and start traffic and at modest speeds in 3rd or 4th gear at 4000 RPM. Your road speed will be slower than you may normally be used to but you WILL be using less fuel in absolute terms because you're using less power.
Like life, riding is full of compromises.
KZ650C2 Stock/mint. Goes by "Ace".
H2A Built from a genuine basket case. Yes,it's a hot rod.
GT550A Stock/mint. Pleasant stroker.
2006 Bandit 1200S for easy LD rapid transit
Various H2 projects in the wings.
- davenkids2001
- Thank you received: 2
My SR is consistently 39-40 MPG. The 650 hit 42. I haven't seen any better than that from either.
Ditto on that here too. I can get about 40MPG riding alone but only about 38MPG with my wife aboard. This is with a sprocket ratio of 16/40.
Pisses me off that my friends who ride Harley's consistantly get 44-45MPG! AND they have more than twice the displacement!
Oh well...my bike is paid for. I guess that counts for sumthin'
Dave and Janet
Great Lake State
1979 650SR
- Shoe48
- Live each day as it is your last
- Thank you received: 5
- WABBMW
- Let The Good Times Roll !
- Thank you received: 16
1. IMHO, a carburetor does not get the best MPG at wide open throttle, since it richens the mixture as the throttle opens beyond a certain point.
2. The faster you go, the greater amount of air has to be pushed aside, which consumes power and fuel in the process. With all other things being equal, you will get better mileage at slower speeds.
3. High RPMs generally do not get as good of mileage as lower RPMs, unless the power is so insufficient that the throttle must be opened rather wide.
4. At the RPM where maximum torque is generated, an engine probably does put out the most horsepower per unit of fuel consumption. On a dyno, with no wind to push, and lots of power being generated, you might start to see some favorable figures. But we are not riding under this condition.
5. At slow speeds, a bike with smaller displacement will generally get better mileage than a large displacement. But as speed increases, the gas mileage decreases for the smaller bike, to a point where the larger displacement bike will actually get the same or even better mileage. The larger displacement can run fast with less penalty than the smaller engine.
5. I have found the best mileage is obtained by using high gear and running about 40 MPH. Of course, you can't get anywhere. I have done numerous studies on mileage, and found my actual mileage has averaged as follows:
40 MPH --- 62 MPG
50 MPH --- 59 MPG
60 MPH --- 57 MPG
70 MPH --- 54 MPG
80 MPH --- 49 MPG
85 MPH --- 43 MPG
Hope every body is not bored to sleep by this.
Bill Baker
Houston, Texas
1982 KZ650 CSR
2008 Yamaha FZ1
2006 Yamaha FZ1
1977 Honda Supersport 750 four (sold)
1984 Honda Nighthawk 650 (sold)
- wiredgeorge
- N0NB
- Blue handles better
Nate
1979 KZ650 (Complete!)
1979 KZ650 SR (Sold!)
1979 KL250 (For sale)
1994 Bayou 400 (four wheel peel )
- oldcuda68
Mark
1980 KZ750 LTD
1984 Honda GL1200 Interstate
Too many other toys to mention
- H2RICK
My second tank this season turned up 49+ MPIG (~39.3 MPUSG)
with half and half city/country riding. As well, none of the riding was done in temps over 17 deg C (64 deg F) and a lot of the city riding was done in temps of less than 13 deg C
(55 deg F) so everything was kind of stiffer than it would have been at 25 deg C (~78 deg F) and above. The cooler temps contribute to rolling resistance as well as internal engine resistance.
Yes, this is splitting hairs but it's amazing how big a difference many little things add up to in the end.
When the temps in Cowtown consistently exceed 25 deg C, I expect to see a nice improvement, even with the stock (fairly deep) gearing.
My .02.....
- ThousandKaw
Depending on depending.
Speed limit?
Is there a speed limit?
\"Shady Slim\"
1951 Indian 80 CI
1974 MT1
1974 F11 X 2
1975 KX250 More fun than a guy should have
1977 KZ1000 Hooker Headers
- Kawickrice
- Thank you received: 18
73 Kawasaki Z1
07 HD CVO Ultra Classic
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
79 RD 400 Daytona Special
72 Honda CL 175
74 Honda QA 50
Tampa FL
- steell
That's riding in fuel economy mode though, slow accel and steady 60 mph cruise, but at $4.00 per gallon for regular unleaded I'll probably continue riding the same way (most of the time anyway).
GPzInfested got 50 mpg on his 750 Turbo while riding with me, by himself he gets 35-40 mpg, I know what he's doing when I'm not around
- Sandy
- Fly High,Tony
- Thank you received: 13
SMILES per gallon?...about 400! :woohoo: :laugh:
1977 KZ1000 A-1
