Restoring a 1981 Z1000J1 in Australia
  • Glenn_22
  • Glenn_22's Avatar Topic Author
Re: Restoring a 1981 Z1000J1 in Australia
23 Mar 2025 14:10
#910420
Has me a bit confused too, someone has gone to the effort of cutting through the rings and spot welding them back together and yet there are 3 out of 4 screws rattling around??
Why is this, are the threads stripped?
If I'm going to attempt to refit the screws should I just repeat this method rather than use the de-crimping process, is that a reasonable course of action?
Another thought I had is that while the rings are off welding/solder some sort of small fittings so the rings can be held in place with small bolts, something like this;
Solder two of these jewellery fittings either side of the cuts and bend the loops up 90 degrees??
The join could be positioned at 5 o'clock in behind the odometer housing to kinda hide it?
or just spot weld it again?
1981 Kawasaki Z1000J1
1983 Yamaha RZ350
1986 Yamaha TZR2501KT
1995 Yamaha TZR250SPR Sugo
2022 Husqvarna TE250i
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Premium Member
24 Mar 2025 11:52
#910467
Hi Scirocco, good jig 😁 you should sell these in kit form, probably a market for them 👍
Rich.
It´s not my construction, a member of the german Caferacer forum build this DIY jig.
The following user(s) said Thank You: Gdizard, kimchella
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Premium Member
24 Mar 2025 12:05
#910469
These ring clamps have a little more diameter to hold some extra chrome cover add-on!
z-fever.de/shop/en/product_info.php?info...omuim-cover-set.html
z-fever.de/shop/en/product_info.php?info...cover-upper-set.html
You need this clamp
z-fever.de/shop/en/product_info.php?info=p1498_ring-clocks.html
  • asphalt900
  • asphalt900's Avatar
24 Mar 2025 12:36
#910470
Highly unlikely they stripped out the face screws. That's a plastic face, they would of burrowed into the plastic before stripping. Looks like a "decal" because of the bubbling on the speedo. I hate decals!! How "NICE" do you want this set?? I have containers full of this stuff not tack-welded or fudged. And if i don't have it i can find it. Just saying because you need the carbs anyway.
The following user(s) said Thank You: Gdizard, Glenn_22
  • asphalt900
24 Mar 2025 13:11
#910475
Still haven't a clue why person's "cut the crimping ring?? Don't know what your upper lip or lower plastic can diameter is, KZ stuff is approx 103mm. I don't use replacements, just remove the existing if proper and polish/replace. Different designs used different rings of course.
  • asphalt900
24 Mar 2025 13:40
#910478
Here is the unsettling reality of decals. Note not all decals are manufactured the same! If doing a speedo with that 45-degree beveled opening for odometer and trip register and wanting to decal it..You're screwed. Can't hope to tuck that decal into the beveled area and even if ya could it's going to lift in time, unsightly!! And the ones from Diablo, former Reproduction Decals are waaay too shiny. If left to no other option i use the decals from "Classic Gauges" or CB750faces" both out of the UK. Ones from Classic have a stiffer backer whereas Diablo are stretchy film. I do a lot of gauges and person's demand excellence so i do the best i can with found bits. Where's Howard, he's a smart cookie!!! He could probably re-screen print the original font!
The following user(s) said Thank You: Scirocco, Gdizard, kimchella
  • kimchella
  • kimchella's Avatar
24 Mar 2025 18:38
#910488
Hi Clay, it’s a good job that I don’t live near you otherwise you wouldn’t be able to get me out of your shed, and would have to start charging me rent😂😂 toooo many goodies for a petrol head like me👍👍
Rich.
KZ650B1 frame number 225
New Zealand
The following user(s) said Thank You: asphalt900, Gdizard, Wookie58
  • asphalt900
25 Mar 2025 03:51
#910499
Oh Rich wouldn't have to even have to consider having to pay anything, i'd have plenty of crap for You to do. It would be the other way around, i'd be paying You!! Have a couple more bikes coming my way shortly. A 1966 Suzuki T250 Hustler and the Holy Grail of the T500 Titans, a 1968. Just never ends...
The following user(s) said Thank You: Gdizard, Wookie58
  • kimchella
25 Mar 2025 10:13
#910521
Ha ha, you are a tempter 😂😂 what a nice couple of bikes coming your way!! are they just to work on, or are they new acquisitions?
New Zealand
  • asphalt900
26 Mar 2025 05:30
#910546
Rich, those are "other" person's machines. I learned years ago working on one's own stuff doesn't pay, it costs, ha. Sold the last 8 Z's i had years ago. Have accumulated a couple since then but i'd gotten the ones sold back when they were either given to me or never paid more then 300usd per bike. The good old days, before everyone had computers.
The following user(s) said Thank You: kimchella
  • Glenn_22
26 Mar 2025 15:34
#910584
Hi Clay How NICE you say? Anything would be better than their current condition, for starters I'm keen to discover if they even work, I haven't started it let alone ridden it so not sure what I'm going to find, po did mention the Tacho worked intermittently (maybe loose wire he said) but I've discovered his word means nought....
The diameter over the clamping ring = ~107mm (not sure how tight the ring was squeezed before they spot welded it)
The diameter over the top case = ~100mm (it's in pretty poor shape, you can see where po tried to prise it off the glass)
The diameter over the lower internal case = ~93mm (white main body)
The diameter of the lower outer case = ~106mm (these are a bit beaten up and have been poorly painted)
The stuff you have (in your photos) are from the earlier KZ900, A3, A4, H etc models?
I think for now I'm going to leave them alone until I get the engine rebuilt and on the road and confirm they work then look at my options to restore them.
What I will do though is use EksCelle brilliant "1981 KZ1000 Speedo/Tach Rubber damper alternative"
Thanks again for your sage advice and offers of help, very much appreciated.
1983 Yamaha RZ350
  • Harroldb
  • Harroldb's Avatar
27 Mar 2025 20:35
#910653
Yeah mate I’m in a group called Z Owners NSW the group’s knowledge is unbelievable & as for parts there’s posts daily, give it a try
The following user(s) said Thank You: Glenn_22
