Woodhead's '77 KZ1000A resto mod attempt.
- WoodheadB2
Re: Woodhead's '77 KZ1000A resto mod attempt.
14 Aug 2026 08:25Wouldn't still be pushing the load at an angle? (Wanting to bend the shaft in the middle as the swinger goes thru it's stroke)Just a suggestion but if you off-set both lower shock mounts by half of your discrepancy (one inwards and one outwards) you could also buy shocks with spherical bearings (or replace the bushes in the shocks you have with bearings) you could then angle the shocks inwards at the top and keep the stock width
[attachment=184448]KZ1000 off set shock mounts.jpg[/attachment
Current ride: 2022 Trimph Tiger Sport 660
First ride: My buddies dad-built mini bike circa 1968
First real bike: 1971 Hodaka Super Rat
Favorite ride: 1987 Yamaha FZR1000
Favorite road: Cherohala Skyway
Favorite movie: On Any Sunday of course!
- zed1015
14 Aug 2026 09:27
An inboard offset lower mount would be the easiest way to go to to keep the distance to the wheel symmetrical with the other side and negate the need to alter the stock frame mounts which you wanted to avoid.
The XJR1300 arms i favour have factory outboard offset lower mounts which have roughly the same amount of overhang .
I would make the mount in one piece though as opposed the two piece design you currently have.
14 Aug 2026 10:44
Cut those tabs off and weld something like this on where you want it.
www.z1enterprises.com/the-dcc-originals-...ck-mount-clevis.html
Bob's your uncle.
Bob's your uncle.
14 Aug 2026 13:35
I think a pair of billet mounts as per my diagram would get it done (the angle on the shocks is exaggerated to show the concept and I don’t believe would cause any twisting
- WoodheadB2
20 Aug 2026 12:19
Sorry I haven't been replying because it's been in the mid to upper 90's and 80% humidity here and my shop has become an air fryer!! it's supposedly going to be cooler in the coming days. More later.
