new to me 1978 KZ 1000
- Treetall
Re: new to me 1978 KZ 1000
06 Mar 2025 21:34The mystery deepens. I wonder if the valve is opening and closing correctly...as already mentioned...how is the clearance?
If you have another carb or a rack of carbs you could try them to see if that helps.
I can't remember if I wrote them down. But I do remember they were all nicely in spec. There wasn't any that were " well it's close enough"
We have a big swap meet coming up on the 23rd, in Red Deer. I will be checking it out.
- Rolf1976_KZ900
07 Mar 2025 01:08 - 07 Mar 2025 01:12
If the plug get wet you have spark and comp it may be fuel not atomizing at all. Check that tip on mixturescrew is not broke off or bent. You also mentioned something about the small o rings on micturescrews earlier maybe one is bad?Check that fuel level is not too high floding You can adjust the float height/fuel level with the carbs in bike.It is a little fiddely but easyer than pulling the carbs .Afterall you have pulled and cleaned the carbs twice so that should be good . You can also try to swap mixturescrews and se if problem move.
Last edit: 07 Mar 2025 01:12 by Rolf1976_KZ900.
- Treetall
07 Mar 2025 20:13
Thanks Rolf
I'll check the mixture screw. I know it's not broken, I checked that for sure. Maybe bent, I'll check it again.
I know it has a small scratch about an 1/8" down from the tip.
I replaced the o-rings from a kit I got from Nessism. I'll check it also.
I was going to do some gut swapping. To see if I can figure out what the heck.
I checked the float levels a couple times as well. It's sitting at 4mm below the carb body, at the bottom of the meniscus.
I just walked away from the ole girl for a day or two. Just a little PO'd. So I started replacing the woodbed on my 81 GMC stepside.
The following user(s) said Thank You: Rolf1976_KZ900
- Treetall
09 Mar 2025 09:13
As the plot thickens or the stomach churns!
I inspected the pilot screw. Not bent or anything.
But I swapped it with a different carb, and no change/fire.
I was able to swap carbs with #4.
Now cylinder #2 runs perfect, and nothing on #4.
so now we know it’s in the carb!
We know it’s getting gas, because the plug is wet and the carb holder is wet as well. When I pulled the carbs off.
So it must be flooding!?
Float level checks out at 4mm at the bottom of the meniscus and no gas coming out of the over flow.
so the float should be good, no hole in it.
I’m starting to lean toward a faulty starter plugger. But wow it has to be dumping a pile of fuel, for it not to fire.
A friend suggested that I just go get another used carb and clean and rebuild it.
But I’ve put so much time and effort into this dumb thing, that it’s almost become an obsession!
09 Mar 2025 11:09
It may not feel like it but you are making progress
- Rolf1976_KZ900
09 Mar 2025 12:31
Ok one more thing you can do is check that the float valve needle dont leak. You can use your mouth and blow into the fuelhose es .If you are able to blow the
float valve needle seat is leaking .When float height is set to low so the fuel level is too high the fuel should come out of overflow tube ,but sometimes it does not and drible into combustion camber and down in engine.
- Treetall
09 Mar 2025 19:44
Wookie and someone else said it had to be in the pilot or starter plunger.
so that's where I went next.
Well, I think got er figured out!
It's the pilot jet.
I swapped #2 and #4 back to their proper places.
Took apart #2 again and checked the starter plunger/choke. And compared it with carb #1.
Nothing different.
I then took out the pilot jets and compared them.
I could see a lot more light through #2 than #1.
So I swapped only the pilot jets from #1 and #2.
Lo and behold #1 wouldn't fire.
I do recall when #2 wasn't getting any gas in the cylinder, that the pilot jet was plugged.
The tiny little wire I tried to push through would only bend.
But it was the right size for the other pilot jets.
So I went to a little stiffer but also a tiny bit heavier wire. This cleaned out the jet. But it looks like it made it too big also!
Go figure!!
So now I'll need to find a pilot jet or set of.
Thanks everybody for all the help and advice.
I'll let you know if my diagnosis was correct, when I get another jet.
It's the pilot jet.
Nothing different.
Go figure!!
The following user(s) said Thank You: sf4t7, Wookie58, Rolf1976_KZ900
- Treetall
20 Mar 2025 20:48
Well... Drinks all around and YEE HAA ! and all that good stuff.
I fixed my mistake/stupidity/oops. What ever we want to call it.
I got a new set of OEM pilot jets and replaced the bad one. Problem cured.
I guess I said earlier I used a wire to unplug the jet, but actually it was the tiniest brill bit I could find.
I don't know what was in the pilot jet that I couldn't get out with a small wire.
Who would have thought that a couple thousands of an inch, could cause a cylinder to flood and not fire!
I've got a bit of a hanging throttle to look into. But I want to take it out and get to operating temp, and see how she does,
Thanks everybody for all the help!
21 Mar 2025 00:18
It's a fact of life that the hardest faults to diagnose are the ones that are "man made"
glad you got there in the end)
- Treetall
27 Jul 2025 20:59
I have an electrical question.
I installed a SH 775 R/R. It's the proper one, with the stamp on the fin.
First I had the positive going into the OEM plug with the fuse. But I wasn't getting enough volts. So I hooked it up directly to the Battery. Positive and negative.
All the connections are solders. I hooked the stator wires ( Yellow, Blue, Red) to the R/R. Eliminating the old plugs, wires, and regulator, rectifier.
Testing all 3 combo's RY, RB, YB. I get 60 VAC @ 4000 rpm. But I can only get 12.62 VDC , at the battery at 4000 rpm.
Is this pointing toward a weak stator? From all the reading I've read on here. It's kinda pointing that way!?
- Treetall
27 Jul 2025 21:39I thought I'd throw in a few before and after pics. I know it's the opposite side. But pretty amazing what chrome polish, aluminum buffer and wax can do!
For now I'm leaving the paint. My friend did a pretty go job, for a home paint job. And sitting outside for 12 years.
The first one is shortly after I got er. The fairing had a big crack in it. I was able to find a fairing with a really good windshield, plus fairing and lowers and a rear rack with trunk. For less than a new windshield.
I really like the look of the naked bike the best. But I'm just not a big fan of being blasted any more.
I've got an almost new front fender to replace the 440 fender this winter. She needs a seat cover and a seat pan ( or fix this one).
I'm going to paint the headers. And possibly frame and engine. Was a blacked out engine, OEM in 1978? I've been looking at pics, it seems it may have been both ways!?
Thanks Conrad
28 Jul 2025 02:22What is the battery voltage when the motor is "off" ?I have an electrical question.
Is the R/R you have "new" or "used" ?
With stator disconnected have you checked the resistance as per the FSM ? (RY,RB,YB should be between 0.56 - 0.84 ohms) also check between each of the three leads and ground
with everything connected put a voltmeter red lead to battery "positive" and black lead to "positive" coming out of the R/R (should be no more than 0.5v)
Connect voltmeter black lead to battery "neg" and red lead to ground wire coming out of R/R (should be no more than 0.3v)
I couldn't see a stator spec in the manual but I believe anything above 50v AC on each leg is OK
