Trying to Rescue a Late 1970s (1977??) Kawasaki KZ1000
- wdhewson
Re: Trying to Rescue a Late 1970s (1977??) Kawasaki KZ1000
02 Jan 2025 16:17
Hi Rob,
I don't think I have a wiring diagram for you.
My 1977 KZ1000 project will need a custom wiring job made up from two butchered harnesses, and some spare wire/connectors. Maybe Spring of 2025???
Nothing quite like the rip of a Big KZ
- wdhewson
02 Jan 2025 16:28
Somewhere in this long thread/project it was suggested that I use a 2X4 and heat to re-shape the KZ1000 plastic chain guard, which I prefer over the chromium guard currently installed.
So I fetched a length of wood and clamped it to the 2X4 where I thought it bowed out. Then used the heat gun to take the plastic to a temperature where I could still touch it, but not for long.
It worked really well!! When I took off the clamps the chain guard was much less mis-shaped.
Thanks guys.
Thanks guys.
03 Jan 2025 03:58Hi Rob, I have put the below together which should help you outWould you happen to have a wiring diagram on how the SH775 is wired into a stock '78 wiring harness with the separate Regulator and Rectifier?A Shindingen SH775 is what's known as a "Series" type R/R. These units help preserve your stator by shutting down power generation when not needed, thus keeping it cooler, which extends life. With a shunt type regulation system, the stator is putting out max power at all times, which isn't needed, and generates too much heat.
I get that some people want to preserve the originality of their bike. What I don't understand is why some people spend $100+ on a shunt type R/R, when good used SH775's can be found for half that much.
The following user(s) said Thank You: rstnick, wdhewson
