And finally, Wookie's 82 begins !
- Rolf1976_KZ900
Re: And finally, Wookie's 82 begins !
27 Feb 2024 08:13
looks cool ! if i buy one of these cowlings can i fit it straight on a kz900 or do i have to fill in the sides ??
27 Feb 2024 09:01You can put it straight on as is (which is what Rob did with the 650 after painting to match) The modifications I did were simply to make it "how I wanted it to be" (sometimes I hate myself for being so "picky" about these things )looks cool ! if i buy one of these cowlings can i fit it straight on a kz900 or do i have to fill in the sides ??
- Rolf1976_KZ900
27 Feb 2024 10:13
Okay i taught that you had to modify the cowling since the forks sits wider.
27 Feb 2024 10:55 - 27 Feb 2024 10:56The ZX9R front end is a little wider but the initial mods where more about not having visible fixings and having it fit nicely around the forks and other brackets. Once on I decided to add the material to the sides so it looked (IMHO) like it has always been there rather than a later "add on" I wanted it tucked in as tight as practically possibleOkay i taught that you had to modify the cowling since the forks sits wider.
Last edit: 27 Feb 2024 10:56 by Wookie58.
The following user(s) said Thank You: Rolf1976_KZ900
- Quofan
27 Feb 2024 17:19Wookie58 I can vouch for "Paintdotnet" as well. A brilliant free program. Gimp is another free one that is very good and similar to Photoshop. www.gimp.orgThanks Howard, my drawing is more "Big Bird" than "Foose" so I will give the link a tryYou going to do a "Chip Foose" drawing
I use a free PC paint program called "PaintDotNet" to "visualise"...
www.getpaint.net/
- MLMG
- See you in the wind.
28 Feb 2024 15:36Thank you, it's taking a lot longer than planned but I am determined to make it the best I can (within my skill set and budget)
- calum
28 Feb 2024 15:46... it's taking a lot longer than planned...
Sounds vaguely familiar...
KZ1000 Restomod (
2000 BMW F650GS
2000 BMW F650GS
28 Feb 2024 15:47... it's taking a lot longer than planned...
- calum
28 Feb 2024 15:49
Worth the time, though. Excellent job on the bodywork.
KZ1000 Restomod (
2000 BMW F650GS
2000 BMW F650GS
03 Mar 2024 00:55 - 03 Mar 2024 00:59
Now the bodywork is about done (just need to trim the Zephyr front fender to fit correctly) I have started working through a few smaller jobs that I need to wrap up prior to strip down for polishing,painting,powder coating etc. I had noticed that the "pre-load" adjusters on the front fork would only adjust through the first half of their travel. I pulled the top of the forks and found that I had made a "schoolboy error" when designing the extensions !! In the stock ZX forks there is a thick washer on top of the spring which the adjuster engages with, I had refitted these on top of the extension tubes. The problem was when the adjuster was wound down the washers hit the top of the "joining sleeves" between the original tubes and the extensions
To resolve this I have cut a rebate in the pre-load extensions and made a "top hat" bush for the adjuster to engage with. Fortunately I was able to harvest the materials required from the scrap ZX9R steering stem I had left over so at least it didn't cost anything to resolve
Now the nosecone is in it's final resting place I wanted to lower the handlebars a little to gain some clearance around the clutch master cylinder. In the absence of a mill the 4-jaw on my little lathe did a great job of trimming the bar risers - now on to the hand controls
Last edit: 03 Mar 2024 00:59 by Wookie58.
The following user(s) said Thank You: howardhb, Rolf1976_KZ900, Quofan
- Rolf1976_KZ900
03 Mar 2024 05:32 - 03 Mar 2024 05:34
Nice work i miss using a lathe have not used one since i was in mechanical school.
Last edit: 03 Mar 2024 05:34 by Rolf1976_KZ900.
