1975 KZ400D - restore project
Re: 1975 KZ400D - restore project
22 Sep 2018 11:12
#791241
There aren't enough e's in CLEEEEEN to describe your bike. Very nice! Ed
  • KZErider
  • KZErider's Avatar
22 Sep 2018 17:06
#791262
Great job. Looks awesome!!!
81 KZ750E2(project), 81 KZ750E2(parts donor), 87 BMW K 75C - got it runnin, didn't care for it, holding for family member, 79 CB650(project) Nomad 1700, VStar 950
  • loudhvx
  • loudhvx's Avatar
23 Sep 2018 08:57 - 23 Sep 2018 08:58
#791297
Pulling the warning flasher didn't make it stop flashing? Then the bike has been rewired differently from the diagram.
The relay substitute for the warning flasher should work. It's pretty simple. The blue wire (switched power wire) might be a yellow wire according to some diagrams. And the black/yellow wire (ground wire) might be plain black. The green/white wire goes to the dashboard light and provides ground to the indicator light.
Don't forget pin 85 must be jumpered to pin 87 (not 87A if there is an 87A).
Last edit: 23 Sep 2018 08:58 by loudhvx.
  • vwrabbit
  • vwrabbit's Avatar
24 Sep 2018 07:04
#791349
Looks fantastic! Hope to see it in person sometime!
1982 KZ440 former LTD
1975 CB125S
2006 VT600 VLX
  • Togoster
  • Togoster's Avatar
24 Sep 2018 19:40
#791390
Yeah, it's great work to be sure. Had a 76 kz400 that I bought new and some quick math tells me I was about 19 back then. I was riding along and a guy from my old high school in a turbo black KZ900 pulled up alongside and asked me how I liked my scooter? Haha.
Not long after I met him again at his old girlfriends house. He seemed a bit down, teary even. I was picking up his old girlfriend for a ride on my "scooter".
We had a good ride!!
Get your motor running!
84 GPZ750
81 R100RS
83 GSX750ES
80 KZ1000 LTD
  • Jack_Mills
  • Jack_Mills's Avatar Topic Author
17 Nov 2019 08:55
#814096
Hey all!
My head gasket on this bike failed a few months ago (3 of the 4 valve stem seals were ripped and leaking badly)...Im just about done putting it back together and I have a question about the 2 bolts on either side of the head (in front of the spark plugs). What is the torque value for those? I have the Kawi service manual, and I cant seem to find this info. Also, the o ring type gasket for the valve cover isnt available anymore (book and online says to use grey/black gasket maker)...the one that was on there is so dry rotten...have you folks tried to recondition this one and also put the gasket maker under it? Or should I just fill the area with the gasket maker only? Perhaps there is some universal o ring type gasket on a spool or specific lengths w the proper diameter? The top end is CLEAN (we vap blasted the parts).
Also, to the guy who was giving me shit some posts ago on this thread about going over the motor before dumping all the time and money into the rest of the bike. I think that is something that has to be learned, mistakes made, to actually realize that if you have the rest of the bike 100% restored, its almost vital to take the motor all the way apart, check all the wearable things, get the parts vap blasted and do it right the first time. Thanks for that, I learned that with this bike. Take care all.
74 kz400 D1
75 kz400 D2
75 kz400 D2
75 kz400 D2
76 kz400 D3
76 kz400 D3
77 kz400 A1
78 kz400 B1
80 xl80s
81 kz440 B2
81 GL1100
81 xl80s
81 xr80
96 K1100LT
18 HAWK250
Thanks goes out to all folks who share their great knowledge teaching others about classic metric motorcycles.
  • Jack_Mills
17 Nov 2019 14:03 - 17 Nov 2019 14:04
#814104
Took the bike out and its running great, no leaks on the top end. I do have another question if anyone has any info...the left side case, where the wires come through the front end of the bottom end, above the sprocket...still leaks no matter what I do. Back in the days, I dont remember having any issues with this...I didnt even think there was supposed to be oil on that side anyways...maybe a little in the bottom to lube the starter chain...IMO I think theres too much oil going to that side of the case, causing pressure (just a guess)...
Anyone have any input? Thanks!
74 kz400 D1
75 kz400 D2
75 kz400 D2
75 kz400 D2
76 kz400 D3
76 kz400 D3
77 kz400 A1
78 kz400 B1
80 xl80s
81 kz440 B2
81 GL1100
81 xl80s
81 xr80
96 K1100LT
18 HAWK250
Last edit: 17 Nov 2019 14:04 by Jack_Mills.
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Premium Member
17 Nov 2019 14:44
#814105
No eBay APP ID and/or Cert ID defined in Kunena configurationSo some dirt could block the oil flow back passage and build up pressure.
BTW: here you can buy the o ring type gasket for the valve cover.
  • Nebr_Rex
  • Nebr_Rex's Avatar
17 Nov 2019 15:46
#814108
Jack_Mills wrote: Hey all!
Well I told...….
As for the O-ring gasket try some small vacuum line from the auto parts store glued in place with rubber cement or tri-bond.
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
The following user(s) said Thank You: Jack_Mills
  • Nebr_Rex
  • Nebr_Rex's Avatar
17 Nov 2019 15:48
#814109
Jack_Mills wrote: Took the bike out and its running great, no leaks on the top end. I do have another question if anyone has any info...the left side case, where the wires come through the front end of the bottom end, above the sprocket...still leaks no matter what I do. Back in the days, I dont remember having any issues with this...I didnt even think there was supposed to be oil on that side anyways...maybe a little in the bottom to lube the starter chain...IMO I think theres too much oil going to that side of the case, causing pressure (just a guess)...
Try a little tri-bond on the gasket.
2002 ZRX1200R
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
  • Nebr_Rex
  • Nebr_Rex's Avatar
17 Nov 2019 15:51
#814110
Scirocco wrote: So some dirt could block the oil flow back passage and build up pressure.
There is no drain back on that side of the early KZ400s.
The late KZ400s and KZ440s do have a drain back cast into the lower case.
2002 ZRX1200R
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
The following user(s) said Thank You: Scirocco, Jack_Mills
  • Jack_Mills
17 Nov 2019 16:02
#814111
...but there is supposed to be a bit of oil in the bottom on the left side, below the stator right? I am having a hard time with this...
I used black/grey gasket maker for the valve cover and its holding. Only ran it for about 15 miles so I could change the oil and what not. Thanks for that link, Im going to buy it for the future.
74 kz400 D1
75 kz400 D2
75 kz400 D2
75 kz400 D2
76 kz400 D3
76 kz400 D3
77 kz400 A1
78 kz400 B1
80 xl80s
81 kz440 B2
81 GL1100
81 xl80s
81 xr80
96 K1100LT
18 HAWK250
