650 SR 1981 (z750L engine)
Re: 650 SR 1981 (z750L engine)
22 Mar 2018 20:13
ajsfirehawk makes an excellent point! Carefully check the bottom rear of that fender to see if it has been modified. Some had the struts wrapped around the back of the fender and attached to holes as in ajsfirehawk's picture, and some had the struts attached to tabs on the fender as shown in the image below. Someone may have modded your fender to eliminate the holes or the tabs. In any case it looks like there's a lot of unsupported fender there that might cause a problem if you hit a bump. Ed
- gordone
22 Mar 2018 23:24ajsfirehawk wrote: Looks good. I do believe there is supposed to be struts from the bottom of the forks to the lower rear of your front fender. If the front fender oscillates enough to catch the tread while you are riding, it is going to be a $hitstorm. Take a hard look at it partner. A pic of my 79 D2 for reference.
Thank you for your feedback. When I got the bike these was missing and I have driven one season without, so I will look into it, but properly have it like now.
Like the design better, if the vibration will give any problem will I think about cutting the lenght of the fenders instead.
Project:
Project:
- JMKZHI
24 Mar 2018 07:18 - 24 Mar 2018 07:24
From internet image searches the KZ650-D4 may not have Fr fender stays, and the 1981 KZ650 manual doesn't show the stays. The JarleF Z650 site has a pic of a D4 without them as well. However, it seems odd that there are 2 holes at the rear of the fender.
Last edit: 24 Mar 2018 07:24 by JMKZHI.
- gordone
24 Mar 2018 10:06
I think the two wholes is for «mudflap»?
Project:
Project:
- ajsfirehawk
24 Mar 2018 12:40
I only see the CSR model for 1981 KZ650's. I think you have a 1980 year of manufacture KZ650. Here is the link to the Partzilla front fender for your model. It has the wrap around style strut and those two holes are for mounting. The fenders that don't have struts are shorter. Longer is better for road crap/rain being thrown on you, and your pipes but if it is a look you are after, shorten it up. I would not leave as is without a strut. Party on.
www.partzilla.com/catalog/kawasaki/motor...ltd-kz650-e1/fenders
80 KZ1000 Z1 Classic
83 KZ1100 LTD
18 Z900RS
23 Mach 1
83 KZ1100 LTD
18 Z900RS
23 Mach 1
24 Mar 2018 19:42
Kawasaki made a 1981 KZ650-F2 (and 1982 and '83 F models) and to my surprise it has the long front fender with no struts. I don't know if any of those models were imported to the US. See link below. Ed
jarlef.no/Kawasaki/Series/Z/650/Z650F.htm
- mopguy
24 Mar 2018 20:07
Have same tires on my bike, I like them, and will buy them again.
- ajsfirehawk
24 Mar 2018 20:17650ed wrote: Kawasaki made a 1981 KZ650-F2 (and 1982 and '83 F models) and to my surprise it has the long front fender with no struts. I don't know if any of those models were imported to the US. See link below. Ed
I've got to believe those models don't have two holes on the back of the fender. Makes me wonder if there was some additional structure inside to avoid oscillation.
83 KZ1100 LTD
18 Z900RS
23 Mach 1
83 KZ1100 LTD
18 Z900RS
23 Mach 1
24 Mar 2018 20:48
Those fenders rely on rivets so it makes sense they would need extra bracing. The Z1/KZ1000's are one piece.
z1parts.net/z1-900-kz900-kz1000-front-fender-35003-015/
- gordone
04 Apr 2018 22:47
Yesterday installed I the rear mud cover and the rear light.
Hopefully will I recive the bolts for the engine, and then can I finish up the engine, be ready to installed in the frame.
I want to do much as possible of other task before I install the engine because of the weather...
Project:
Project:
- gordone
08 Apr 2018 10:24SWest wrote: Those fenders rely on rivets so it makes sense they would need extra bracing. The Z1/KZ1000's are one piece.
I will looking into replace the fender in the future, don`t like the way its mounted with the bolt on top... more smooth design the fender you have linked to.
Project:
Project:
- gordone
11 Apr 2018 13:03
Today have finish rebuild the engine, installed the last shim I have waited for in the mail. Now the valve clearance is between 0,10-15mm and approx around 0,12-0,13.
I have installed new "cop holders" over the shims, after that is was easy to measure the valve clearness so the old one was properly not 100% flat. I have also installed new carb. holder (rubber inlet). I will soon install the engine in the frame. Looking forward to it
Hopefully can I start up the engine during the month.
When I cleaned the old front light reflector it damage it.. the silver layer was going of... so I have order new reflector, the old look to be orginal, so it was properly time for replace it anyway, so get good light again?
Project:
Project:
