The Ongoing Chapters of the 650B2A.
  • Johnbug
  • Johnbug's Avatar Topic Author
Re: The Ongoing Chapters of the 650B2A.
26 Apr 2017 09:51
#760303
Float bowls all adjusted to about 3MM. Next up on the adgenda is to get some new bolts for the carb holders and then think up a good way to make sure they hold vac seal. Then its reassembly of the fuel system and straightening of the back wheel! Then hopefully my first ride out on this thing.
Proud Confused Owner Of A KZ650B2A
26 Apr 2017 10:33 - 26 Apr 2017 10:34
#760304
Assuming you bought new carb holders you do not need to do anything extraordinary to make them seal. Just make sure there's no muck on the cylinder head where they mate up and mount them dry (NO sealant) and they will seal just fine. Ed
Last edit: 26 Apr 2017 10:34 by 650ed.
  • Johnbug
26 Apr 2017 20:26
#760351
Actually I cleaned the surrounding area and replaced all the bolts into the holders with their correct metric counterparts. I got the bike running and idling correctly! After about a 3 minute warm up it would throttle up and ran much better! No more runaway idle! The float issue seemed to he causing it. In fact I took it for its first ride ever the moment this was done and the idle was sorted out. I was laughing and cackling like a child that was so much fun! It seemed to have a very crispy throttle response and shifted about like I expected. I need to tighten up the throttle housing a tad and adjust the Throttle.. Put a bit more air in the tires and then it will be perfect. Thank you guys for helping me getting this running! Ill keep working on it and making it look amazing as I recently picked up some old paint guns. Tomorrow if the weather holds out I'm going to go out again.
  • Johnbug
27 Apr 2017 09:48
#760397
Discovered a exhaust leak again. Awfully scary looking since it makes it seem like smoke is blowing out of the engine. Put I think I just need to replace the exhaust gasket. Will keep posted on any new developments.
  • rstnick
  • rstnick's Avatar
  • Premium Member
  • Premium Member
30 Apr 2017 11:37
#760775
Good to hear you've got her running better.
B)
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
