82 kz1000 ground up build
- jowek70
Re: 82 kz1000 ground up build
04 Mar 2024 06:33
3d printed a mock up for the gauge mount to fit the motogadget gauge.
Fit great so i'm gonna have one made from aluminum and get the gauge on order.
- jowek70
12 Mar 2024 04:46
The following user(s) said Thank You: sf4t7, howardhb, Rolf1976_KZ900
- jowek70
02 Apr 2024 10:13
Finally had my stem bearings show up; should have front end on today, got the rear end buttoned up and picked up a 520 44t black sprocket for $15. Gonna order brake lines, the muffler, get the header welded up and slap on the radiator and coolant reservoir. Should have most of the mechanical portion done then its time for the gauge, headlight, tail light, fuel pump and the wiring harness.
- jowek70
11 Apr 2024 10:10
Few minor things accomplished; spent a lot of time on the other project bikes in my garage but hoping to get back into this one this coming weekend.
- jowek70
24 Apr 2024 05:34
Ordered brake lines, installed front and rear fenders, mounted battery box and radiator mounts and waiting on a few parts in the mail yet. Found the muffler i want to run so i'll be picking that up when i'm in tennesee next month. Have everything to put the bike together but still need to sort out the fuel pump set-up and get the bike on the dyno. Hoping to be riding by June 1.
- jowek70
02 May 2024 04:14
painted the gas cap and got a few things sorted.
- jowek70
07 May 2024 04:24
side cover grommets installed, mocked up body work one last time before storing it in boxes until the engine and exhaust and wiring is complete.
07 May 2024 04:28
The following user(s) said Thank You: jowek70
- jowek70
03 Jun 2024 05:11
ended up going a different route with the header set-up; originally was going to use the OEM one from my zx10 but ran into fitment and complexity issues so ended up snagging a titanium one for the the 03-06 z1000 for $100 off ebay and got it fitted but will have to do some fab to make the muffler section work.
03 Jun 2024 05:41
- jowek70
03 Jun 2024 06:30
Yeah, the #3 header tube is tweaked a little bit so gotta see if my welder can fix it up for me. As for the tube, i have a couple ideas but need some time to weigh the options. Without the bar there it makes fitting the OEM filter much easier, haha.
- jowek70
05 Jun 2024 07:48
Teaser pic:
Really thinking of a brown seat. Waiting on color samples from supplier. Sorting out cable lengths with Venhill USA and then i have to order a few expensive things to continue assembly; due date is 08/01/24.
The following user(s) said Thank You: Scirocco
