Getting a 82 KZ1100A2 survivor this weekend.
  • SmokyOwl
  • SmokyOwl's Avatar
Re: Getting a 82 KZ1100A2 survivor this weekend.
27 Aug 2016 22:59 - 27 Aug 2016 23:01
#740205
GPzMOD750 wrote:
swest wrote: Sounds like air shocks. Will they hold air?
That's what I was thinking but I don't want to blow a seal by over filling them to begin with. Anyone know max pressure?
I know, get the FSM. I will as soon as I get caught up a little, I've had to register 3 vehicles this month, buy a set of tires, pay for school start up crap, buy a new radiator, buy and rebuild a head, find new bike parts.....
My manual for my '82 KZ1100 A2 says....
Front shocks 7.1 to 10psi
Rear shocks 5.7 to 21psi
Another thing that affects my handling....tire pressure.
Manual has a nifty little graph, but I'll do my best here.
US and Canadian Models:
Front 28psi
Rear 28psi for loads up to 97.5kg (215 lbs)
Rear 36psi for loads between 97.5kg (215 lbs) to 190kg (418lbs)
Other than US & Canadian Models:
Front 28psi (under 210 kph)
Front 32psi (over 210 kph)
Rear 28psi (under 210 kph) with load up to 97.5kg (215lbs)
Rear 41psi (over 210 kph) with load up to 97.5kg (215lbs)
Rear 36psi (under 210 kph) with load between 97.5kg (215lbs) and 190kg (418lbs)
Rear 41psi (over 210kph) with load between 97.5kg (215lbs) and 190kg (418lbs)
Apparently the "Other than US & Canadian Models" have issues going over 130mph so they put in a whole column in the graph about it. Likely the US & Canada said "NO! you cannot go that fast!" :angry:
Anyways, hope this helps. :cheer:
1982 Kawasaki KZ1100 A2, Shaft
Never trade the thrill of living for the safety of existance.
Last edit: 27 Aug 2016 23:01 by SmokyOwl.
The following user(s) said Thank You: GPzMOD750
  • GPzMOD750
  • GPzMOD750's Avatar Topic Author
28 Aug 2016 04:36 - 28 Aug 2016 04:38
#740212
Thanks Smoky.
That's just what I need, I checked it yesterday. The rears probably had the minimum,4.4 by the time I had a good reading. The front had barely enough to hiss when I put the gauge on. I put 8 in the back and 9 in the front. I'll go put a bit more in the back.
Well besides the speed limits in US and Canada. The US had the problem of only having 85 mph speedometers. I don't know what numbnuts bureaucrat thought that one up but you'd think the though of "What if someone actually does get on the throttle and exceeds 85 mph? It might be good that they know how much faster they are going before they hit that tight turn." MIGHT have occurred to them.
I'm still looking for a speedo that I can use that's higher than 85.
Last edit: 28 Aug 2016 04:38 by GPzMOD750.
  • GPzMOD750
28 Aug 2016 05:33 - 28 Aug 2016 06:06
#740216
So, What differences I would expect if I took the 17" rear rim off the 1000 and replaced the 16" on this one?
Last edit: 28 Aug 2016 06:06 by GPzMOD750.
  • SWest
  • SWest's Avatar
  • 10 22 2014
28 Aug 2016 06:00
#740218
Your gearing would be a little taller. Read what it says on the tire about air pressure. They aren't all the same. What came stock may not even be available anymore.
  • GPzMOD750
28 Aug 2016 06:09
#740220
Maybe I'll try it for kicks when I get a chance.
  • 531blackbanshee
  • 531blackbanshee's Avatar
  • Vendor
  • Vendor
02 Sep 2016 05:43
#740862
i've got a pdf of the kz1100 service manual.
it's 77,872kb
i'll share however i can.
  • GPzMOD750
Re: Re:RE: Getting a 82 KZ1100A2 survivor this weekend.
02 Sep 2016 05:53
#740867
531blackbanshee wrote: i've got a pdf of the kz1100 service manual.
it's 77,872kb
That would be awesome!
Can it be uploaded to the file base?
  • GPzMOD750
Re: Re:Getting a 82 KZ1100A2 survivor this weekend.
02 Sep 2016 06:21
#740872
  • 531blackbanshee
  • Vendor
  • Vendor
02 Sep 2016 08:59
#740909
it's 77,872kb
i went and looked in the file base and couldn't see a way to upload it.
  • 531blackbanshee
  • Vendor
  • Vendor
02 Sep 2016 09:03
#740910
i can try to email it.
  • GPzMOD750
Re: Re:RE: Re:Getting a 82 KZ1100A2 survivor this weekend.
02 Sep 2016 09:12
#740912
531blackbanshee wrote: i can try to email it.
Give it a try, it might be too big.
Govtmod (at) msn.com
If it won't go you might want to check out one of the file transfer services in the article I posted.
  • 531blackbanshee
  • Vendor
  • Vendor
02 Sep 2016 11:19 - 02 Sep 2016 11:21
#740927
www.adrive.com/public/wWN2Qk/KZ1100man.pdf
i also sent you an email with the link.let me know if it works.
Last edit: 02 Sep 2016 11:21 by 531blackbanshee.
