1980 550 LTD dual sport/cafe project
  • neuropsych
  • neuropsych's Avatar Topic Author
28 Dec 2015 16:19 - 28 Dec 2015 16:20
#704685
So I got my bike in a trade about six months ago. It ran, but poorly. It had a top end and carb rebuild, but then had been left to sit in a shed for a year.
Attachment 12431550_542255702603899_1388699026_n.jpg not found
Mechanically its all there, just sort of disorganized and in need of a good tune and a refresh.
So far, I've bought a replacement tank for it, sent the carbs to a local shop for a fresh rebuild and ultrasonic cleaning, and removed all the aftermarket and broken pieces.
As it sits now, it looks like this -
Attachment DSC_0009.jpg not found
Here's a concept drawing of what I want to eventually do with it-
Attachment IMG_0012.jpg not found
Other than that, I'm planning on mounting some dual sport tires and lowering the front end down an inch or two.
The only issue I'm really running up against so far is how in the world to get rid of that crap little 16" rear wheel. The 550A drum brake 18" alloy doesn't seem to exist, so I guess I'll have to switch to rear disc brake and change the front wheel too.
Last edit: 28 Dec 2015 16:20 by neuropsych.
  • loudhvx
  • loudhvx's Avatar
Re: 1980 550 LTD dual sport/cafe project
28 Dec 2015 16:26
#704687
I like it. If you are really going for dual sport, and you have the ability to do some minor fabbing, I bet you could get some nice aluminum wheels with spokes. That would be a rare 550 then, plus the dual sport tires look more appropriate on spoke wheels.
  • kz n az
  • kz n az's Avatar
28 Dec 2015 16:32
#704689
Hello That's a nice clean looking bike. I kind of favor the cafe look.
Will be watching.
  • neuropsych
28 Dec 2015 16:47 - 28 Dec 2015 17:05
#704692
You're definitely right about the spoke wheels. I'd considered it, but couldn't find any model of kawi that would be a straight swap.
Maybe wheels and a swingarm from a kz650/csr650?
Also the shoestring budget starts to come into effect, so any wheel swaps are probably a ways off for now.
I'm really just trying to make the best all-rounder bike that I can.
This will be my daily as soon as the carbs are back on and some safe tires are mounted. Maybe even before i get the seat upholstered!
I have this crazy idea that when its finished I'll take it on a road trip out to the west coast, so reliability and ease of repair/replacement parts are also a must.
thanks for the replies guys
Last edit: 28 Dec 2015 17:05 by neuropsych.
  • neuropsych
28 Dec 2015 17:18
#704695
Also, another question:
Is there any way to retrofit a kick start onto this bike? The idea of being utterly reliant on the battery to start the bike is a bit daunting.
  • floivanus
  • floivanus's Avatar
28 Dec 2015 18:59
#704700
Nope, no way to do that, if you want kickstart, sell the 550 for a 400, 440 or 650
Past; 78 kz1000, 83 kz550
Andrew
  • loudhvx
  • loudhvx's Avatar
29 Dec 2015 06:36
#704733
No kick, but the 550's are real easy to bump start when you get a little practice. The bike in my avatar has no battery. I've been bump starting it for about 7 years. With a battery, on a different bike, you can bump start them practically from a walk.
The following user(s) said Thank You: neuropsych
  • neuropsych
29 Dec 2015 07:29
#704742
Ah, okay. That works fine then.
I'll be picking the carbs up tomorrow, so hopefully I'll have a running bike again by the afternoon.
  • SWest
  • SWest's Avatar
  • 10 22 2014
29 Dec 2015 07:46
#704746
If you'll notice, the rear tire is taller than most. This is to compensate for the smaller rim. In the day, guys were going to 16" rims not only were the tires cheaper and you got a little more low end, it looked cool. I didn't like it because I'd lose ground clearance. Being 6'1", seat height wasn't a issue. As long as they make the taller tire, I think you would be at about where a 18" rim would put you.
  • neuropsych
29 Dec 2015 07:51
#704747
I haven't had a problem finding tires that would fit the 16", its just a aesthetic thing really.
I just don't like the big and little wheel combo.
Otherwise it really doesn't affect anything. Maybe the handling is a little softer than with an 18".
Thats why I'm not in any huge rush to swap the wheel set out.
  • loudhvx
  • loudhvx's Avatar
29 Dec 2015 10:32
#704778
I think the reason for the small wheel was so it could use a big tire, in an effort to mimic muscle cars. The overall outside diameter ends up around the same (but may be wider). I don't think the small wheel/big tire looks all that bad for a muscle bike look. It may also be ok for a dual-sport as dirt bikes tend to also have small rear wheels. The only real problem is that some riders say the small-wheel / big-tire combo handles poorly compared to the 18" rear wheel. If you are not looking for high-speed maneuverability, and money is an issue, you will be best off using what you got. Looks-wise, I think it'll be fine.
  • SWest
  • SWest's Avatar
  • 10 22 2014
29 Dec 2015 13:41
#704806
Unless the tire has strong side walls, there could be handling issues in the turns.
