1980 KZ550
- loudhvx
Re: 1981 KZ550
09 Nov 2015 12:19 - 09 Nov 2015 12:29
Make sure the magnets on the pulser are mounted correctly in regards to north and south polarity, or it won't work or time properly.
Also, make sure to have the brass screws and the steel screws in the correct place. If you use steel screws where the brass ones were, the magnetism will be weak and the ignition signal will also be weak.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
Last edit: 09 Nov 2015 12:29 by loudhvx.
- rrsmsw9999
Re: 1981 KZ550
09 Nov 2015 12:22
+1 will do. R
1980 KZ 1000E2
Crashed 6/2016
1980 KZ550A
Sold 3/2016
Crashed 6/2016
1980 KZ550A
Sold 3/2016
- rrsmsw9999
Re: 1980 KZ550
11 Nov 2015 06:53
Latesg
1980 KZ 1000E2
Crashed 6/2016
1980 KZ550A
Sold 3/2016
Crashed 6/2016
1980 KZ550A
Sold 3/2016
- rrsmsw9999
Re: 1980 KZ550
11 Nov 2015 06:54
Latesg
Attachment IMG_20151111_105208565.jpg not found
1980 KZ 1000E2
Crashed 6/2016
1980 KZ550A
Sold 3/2016
Crashed 6/2016
1980 KZ550A
Sold 3/2016
Re: 1980 KZ550
11 Nov 2015 10:06
Pretty
- rrsmsw9999
Re: 1981 KZ550
13 Nov 2015 03:38
So the fun keeps going. I went to drill and tap some seized bolts on the output shat tranny cover and first tink with the center punch cracked the top lobe of the cover where the sprocket guard attaches. Anyone have one of these spare and laying around they want to part with?
R
R
Attachment s-l225.jpg not found
1980 KZ 1000E2
Crashed 6/2016
1980 KZ550A
Sold 3/2016
Crashed 6/2016
1980 KZ550A
Sold 3/2016
Re: 1981 KZ550
13 Nov 2015 04:30
I can't help with the part, but for future reference I strongly suggest you get a can of Kroil. An industrial engineer friend told me about it, and it has been a lifesaver to me. This stuff will break the 30+ year bond that seizes fasteners. I have used it on a number of totally stubborn fasteners on my bike that otherwise would have broken off. Let it soak in for about 3 days (applying it again each day) and it will make removing stubborn fasteners possible. It creeps along the fastener through microscopic paths and softens the corrosion. Some gun shops or gun shows carry it, otherwise it can be ordered online from
www.kanolabs.com
. Here's the product I use (Kroil 1/2 pint (8 oz.) can - $9.50 ea.); one can will last a lifetime. Ed
Attachment Kroil-5.jpg not found
The following user(s) said Thank You: rrsmsw9999
- rrsmsw9999
Re: 1981 KZ550
13 Nov 2015 05:37
Thanks Ed, I will not remove another fastener w/o it. I found the cover on Ebay. A $40 + gasket 1 second mistake arrghhhh. Planning on first start this weekend. R
1980 KZ 1000E2
Crashed 6/2016
1980 KZ550A
Sold 3/2016
Crashed 6/2016
1980 KZ550A
Sold 3/2016
- rrsmsw9999
Re: 1981 KZ550
13 Nov 2015 05:38
Do you brush apply? R
1980 KZ 1000E2
Crashed 6/2016
1980 KZ550A
Sold 3/2016
Crashed 6/2016
1980 KZ550A
Sold 3/2016
Re: 1981 KZ550
13 Nov 2015 07:09
I didn't. My can came with a thin spout that can be used to squirt/drip the Kroil onto the fastener (see below). I bought my can several years ago, but I assume the spout is still included. Ed
Attachment IMG_5335.jpg not found
- GPzMOD750
Re: Re:1980 KZ550
13 Nov 2015 07:31
They sell it in a spray can. It's called Aerokroil. I prefer this since you can't always reach what your trying to oil. Makes a bit more of a mess but you get more saturation....
I found mine at a local industrial supply house. Before that I hadn't seen it since AutoZone stopped carrying it.
- rrsmsw9999
Re: Re:1981 KZ550
13 Nov 2015 11:43
She's Alive. Time for the deep dive. R
1980 KZ 1000E2
Crashed 6/2016
1980 KZ550A
Sold 3/2016
Crashed 6/2016
1980 KZ550A
Sold 3/2016
