Saving a 1980 750 twin.
- 80B4
Re: Saving a 1980 750 twin.
16 Feb 2017 09:39
The caliper mounts are a nice touch! I have one of those calipers that I want to try on the front of my DR650 project.
1980B4 1000
1978 Z1R
1978 B3 750
1978 Z1R
1978 B3 750
- DoctoRot
15 Mar 2017 10:08Please Log in or Create an account to join the conversation.
- DoctoRot
29 Mar 2017 11:24
So i have been thinking about the design for the muffler, and am wondering what size to make the baffle. The collector I made is 1.875"OD/1.75"ID. I see that Cone Engineering has their "quiet core" mufflers choked down to 1" and they also have the straight through mufflers. Should I make the baffle smaller than the collector? I can't find any 1.875" perforated tube, but I can find some 1.75" Thoughts?
30 Mar 2017 06:07
i've got a cocktail shaker on a stepped pipe i built for a buell blast project.
it has a 1.750 in and out with a perf tube baffle with the bottom plated over.
looks like the baffle is prolly a foot or so long.haven't heard it run yet tho :pinch: so i can't speak to sound.
but that is a real common size for 650/750 twins and would at least be a good starting point.
- GPzMOD750
30 Mar 2017 17:42
Looking awsome!
I might have to talk you into making some covers for my GPz.....
- DoctoRot
02 Apr 2017 01:53Please Log in or Create an account to join the conversation.
- diggerdanh
- DoctoRot
03 Apr 2017 15:13
I have been fiddling around with the foot controls. got the kick-starter painted with a new detent spring and ball, shifter and rear brake arm are drilled and painted. The stock brake lever was bent pretty badly from where the PO layed it down, so I bent it back with fire. I still want it a little closer to the motor but its much better.
The brake linkage is getting fouled by the new swing arm, so I am going to cut the tab on the brake lever where the linkage connects and move it out some. The problem this creates is that the brake pedal linkage mount is now no longer planar to the rear brake drum arm, and has to be bent into a dogleg to clear the swingarm. I mashed on the pedal pretty hard and it didn't seem to bend the dogleg linkage back hardly at all, but it still makes me wonder if its good. I'm thinking about making a new linkage rod out of chromoly and doglegging it. Thoughts?
04 Apr 2017 06:04
i think i would use it and observe it for a bit and make my decision from there.
- DoctoRot
05 Apr 2017 23:23
I decided to get rid off the stock brake pedal push pad in order to bend the brake pedal tucked in closer to the motor. I turned a steel bung and knurled an aluminum the push pad, welded that on and modded the linkage mount.I already had some 1/4" - .065 wall 4130 laying around so I made a new linkage by TIG brazing a clevis to one and and threading the other, but the threads are kinda rough and shitty, which has been my experience in machining 4130 as well. I think I might cut those threads off and braze some stainless "all-thread" on.
- diggerdanh
06 Apr 2017 05:34
That does look nice and tucked in. Interesting idea.
- DoctoRot
09 Apr 2017 13:32
rear brake lever and linkage finished and painted. I also turned up and polished a bunch of brass washers on the lathe, for the footpegs, shock mounts, and steering stem bolt. I wanted to try and pull a little gold into the scheme since i put the gold stripe on the tank. Tons of little things have been finished. The list of remaining stuff is short. Here is a bunch of gratuitous pics of it in the sun for the first time in months.
