Saving a 1980 750 twin.
  • 80B4
  • 80B4's Avatar
Re: Saving a 1980 750 twin.
16 Feb 2016 08:13
#710905
Vic,
You could put that new speedo right up front like the old Vincents.
1980B4 1000
1978 Z1R
1978 B3 750
  • DoctoRot
  • DoctoRot's Avatar Topic Author
16 Feb 2016 12:08
#710936
Jon - I agree with you. I'm starting to think that this headlight might not be right for this bike which is a bummer because i have alot of time in this headlight bucket and wanted to use it, I am a fan of small headlights but i think the next size up (6.5") might be a better fit for this. I will have to do some searching.
The headlight ears above are just mocked up right now. Once I decide on the final position of the headlight I will make some hollow forms to weld to the clamps and rotate the pinch points into the inside so they are less visible. I personally don't like the look of that Vincent gauge it looks like an afterthought.
  • 80B4
  • 80B4's Avatar
16 Feb 2016 13:07
#710948
Vic,
I don't know the history of Vincent motorcycles well enough to know when that large Smith's speedo became part of the design so it could very well be an afterthought. I have always been aware of the way the gauges impact the visual balance. I will be using one of the Speedhut combination units on my GL1000 project too.
1980B4 1000
1978 Z1R
1978 B3 750
  • DoctoRot
16 Feb 2016 22:06 - 17 Feb 2016 03:15
#711029
Had a little down time today so I re did the gauge housing. The threads are much nicer this time. You can see the one on the right has less chatter in the thread. I also added a little lip that I will leave polished with the rest painted.
Last edit: 17 Feb 2016 03:15 by DoctoRot.
  • 531blackbanshee
  • 531blackbanshee's Avatar
  • Vendor
  • Vendor
17 Feb 2016 06:07
#711045
kickass job looks awesome. :evil:
  • GPzMOD750
  • GPzMOD750's Avatar
17 Feb 2016 06:14
#711046
531blackbanshee wrote: kickass job looks awesome. :evil:
If your skills keep improving at this rate you'll have to open your own custom shop and make a kick ass living at it.
  • DoctoRot
17 Feb 2016 21:30
#711208
Thanks guys. B)
  • DoctoRot
25 Feb 2016 19:26
#712539
I picked up this 6.25" headlight. I think the proportions are much nicer now.
  • 80B4
  • 80B4's Avatar
26 Feb 2016 04:38
#712553
That does look better. The speedo/headlight proportions work.
1980B4 1000
1978 Z1R
1978 B3 750
  • DoctoRot
26 Feb 2016 18:08
#712660
Got a start roughing out the footpeg brackets today
  • DoctoRot
28 Feb 2016 19:21
#712998
Got some more work in on the footpeg brackets. I screwed up and mis-calculated the chamfer on the folding boss and cut too deep. So I fired up the tig and put a dab on there and filed it back down. It looks ok. It's on the bottom so you won't see it when it's mounted. Still a ways to go. I have no real clue what I'm doing so the going is slow.
  • 531blackbanshee
  • Vendor
  • Vendor
29 Feb 2016 05:57
#713024
nice carving so far sir!!! :evil:
