- Thank you received: 7
Kiwi KZP
- KZP15
- Ed_in_Miami
- Thank you received: 46
Subscribed for further updates!
This is my build:
kzrider.com/forum/11-projects/600312-ano...rtment-build?start=0
There are many more like it, but this one is mine... news to come!
- larriken
- Thank you received: 61
- Thank you received: 2744
- larriken
swest wrote: What pistons are those?
They are Moriaki pistons that were made for race kits. They are standard bore size so as to keep them under 1000cc for the race classes but with high comp. I am matching them up to GPZ1100 cams.
- larriken
- larriken
swest wrote: 11/1?
I worked it out that with the cams I am using iit should be 11.5/1
- missionkz
The center cylinder overheated and crapped out twice within 5,600 miles. Eventually pulled them and used 9.5:1 Pistons, then it ran perfectly happy and much fun.
Bruce
1977 KZ1000A1
2016 Triumph T120 Bonneville
- larriken
- missionkz
Just remember that as you do that, it alters the cam/valve timing due to the distance between cam sprockets, fixed number of cam chain pins and crank sprocket, all relative to crankshaft degrees of rotation. Geometrylarriken wrote: Funnily enough I have pondered it a few times for a bike running on pump gas. I have extra base gaskets at .04 and .02, on hand just need to sit down with the calculator and have a work out.
Bruce
1977 KZ1000A1
