GPz550 Project Bike at a snail's pace
  • Tusch
  • Tusch's Avatar Topic Author
02 Mar 2014 16:49
#623928
I bought this bike about a little less than a year ago, cleaned it up a little bit and ran it till it got cold. Had to rewire some things, removed/replaced some other things otherwise, here's a few pics of its progression so far.
[IMG
[IMG
Couple pics the day I picked it up.
1983 GPZ550
  • Tusch
Re: GPz550 Project Bike at a snail's pace
02 Mar 2014 16:50
#623929
New turns front and rear, with solid state flashers and relays to allow 2wire turns to act as running and turn signals. Got a new smaller battery, relocated to the tail. Cleaned up all of the PO's shoddy wiring. Removed the fairing and one side cover. Changed filters, plugs and wires. New grips and bar ends, a phone mount as well as a USB charger wired in.
1983 GPZ550
  • Tusch
02 Mar 2014 16:52 - 02 Mar 2014 16:54
#623930
Here is a mock up I did of my plans using the tank and frame of my parts bike:
[IMG
I got Leon to swap stems for me as I'll be running a zx7r front end. I've got an '09 zx6r swingarm on the rear, a stock seat that I like a whole lot more than the stepped one I had on there and a 650 tail.
1983 GPZ550
Last edit: 02 Mar 2014 16:54 by Tusch.
  • Tusch
02 Mar 2014 16:53
#623932
Well my buddy is 3D printing headlight brackets that I designed. I've been trying to model up my mods as I go so here are a couple screenshots of my front end. I plan on painting the zx7 forks for a carbon-gray color. The brackets themselves will be printed in black and the plates and spacers that reach out to the headlight will be silver, all abs.
[IMG
[IMG
[IMG
[IMG
1983 GPZ550
  • Tusch
02 Mar 2014 17:01 - 02 Mar 2014 17:01
#623934
I've got a black round light, renthal bars and risers, ducati monster taillight, led turns front and rear, 650r rear wheel (looks just like an 05+ zx6r wheel but only 4.5" instead of 5.5") and more plans than I can keep track of at this point. Another coworker and I will be doing the design work on the shock mount and whatever subframe I end up going with.
[IMG
1983 GPZ550
Last edit: 02 Mar 2014 17:01 by Tusch.
  • Tusch
02 Mar 2014 20:18
#623967
[IMG
[IMG
Found an already rendered handlebar on grabcad so I stripped it down and threw in a headlight that matches mine in size for an overall frontend look. I am liking where this is going!
1983 GPZ550
  • spdygon
  • spdygon's Avatar
02 Mar 2014 21:11
#623973
Cool project ...looks like you have it under control.
Will be following your project.
1978 Kz1000 Z1R. 10K Miles1
1978 kz1000 z1r 27k miles
1976 Kz900A4 (Red)21K miles
1976 Kz900A4 ( Red)7500 miles
1974 Z1 900 project
  • 531blackbanshee
  • 531blackbanshee's Avatar
  • Vendor
  • Vendor
03 Mar 2014 08:28 - 03 Mar 2014 08:28
#624002
i am thinking this will be the first project we have seen on here that will use 3-d printed parts :evil: !
super cool,i am loving your vision for the project,
keep us posted.
Last edit: 03 Mar 2014 08:28 by 531blackbanshee.
  • Tusch
03 Mar 2014 08:35
#624003
For some reason my buddy with the printer is focusing on paying jobs instead of mine!? So I should be able to show mock ups of the headlight mounts by the end of the week
1983 GPZ550
  • Tusch
08 Mar 2014 13:46
#624537
[IMG
Found some time and motivation. Jumped into tearing it down. Gotta sell the wheels and front and rear ends to fund some more parts. (Hint hint if anyone needs some GPz bits)
In other news mg buddy came through with the headlight brackets, he only printed 2/4 to start but I should get the rest including the plates Monday.
1983 GPZ550
  • Tusch
09 Mar 2014 11:58
#624618
[IMG
Well as the weather gets nicer I get farther from riding haha
1983 GPZ550
  • Tusch
10 Mar 2014 09:09
#624708
[IMG
So the plate came in a little thinner than intended... Think it'll hold? Haha
It was his first time running that color and he needs to dial in the feed and speed of the extruder for it. He had to stop the print early due to unequal print thicknesses but hopefully I'll be mocking up the completed mount soon.
1983 GPZ550
