GPz550 Project Bike at a snail's pace
  • 531blackbanshee
  • 531blackbanshee's Avatar
  • Vendor
  • Vendor
Re: GPz550 Project Bike at a snail's pace
25 Mar 2014 07:13
#626488
the lil koso is sweet.
if you don't mind my asking what did it set you back?
  • Tusch
  • Tusch's Avatar Topic Author
25 Mar 2014 09:56
#626522
Got it for about $140 on Amazon. Pretty excited but it'll be a while before I get to that haha
1983 GPZ550
  • Tusch
25 Mar 2014 15:07 - 25 Mar 2014 15:25
#626543
[IMG
Ooooh shiny. Pine Sol soak comes recommended by me, still need to blow air through all the carb passages but I just wanted to give everything a good cleaning. For the record the oil cooler lines were black when I started the soak
1983 GPZ550
Last edit: 25 Mar 2014 15:25 by Tusch.
  • Keeter
  • Keeter's Avatar
24 Apr 2014 20:39
#630301
Are those the TK-26 carbs? I'm about to pull mine and clean them. Any advice on the PineSol? did you cut it with water at all? How long did you soak for? They look like they turned out amazing.
1983 KZ550F Spectre Shaft Drive
w/ TK-26 CV Carbs
  • 80B4
  • 80B4's Avatar
25 Apr 2014 06:14
#630327
Nice project, I'll be keeping an eye on this one.
1980B4 1000
1978 Z1R
1978 B3 750
  • Tusch
25 Apr 2014 10:35
#630376
Sorry I haven't gotten anything done at all. I'm closing on my first home soon so been a bit busy. Will probably be able to dive back in after the move.
As far as the pine sol goes, yeah I did about a 50/50 blend with water. Make sure everything you soak is 100% submerged because if it dries out on the surface you pretty much have to start over to remove it. Just soak it, mixing, shaking or stirring every so often until it feels/looks clean. Than give it all a real good rinsing to get all of the pine sol off and use blowing air to ensure its clean and dry.
(Also I'm a newb so take what I say with a grain of salt, but everything has gone well so far)
1983 GPZ550
The following user(s) said Thank You: Keeter
  • Tusch
26 May 2014 09:02
#634031
[IMG
Packing up for the move! Hard to believe there's do many parts of such a small bike.
1983 GPZ550
  • Tusch
19 Mar 2016 18:18
#716242
I worked on the bike!!!! After buying a house, moving, losing much of my stuff (in my garage) and having a kid, I made time and got some shit done today.
My buddy and I got the front thrown on and the swingarm on. Everything is just mocked up (wooden dowels for pivot and axle) and tacked in with scrap but we now know it will all work. We're going to get it all designed up and start cutting final pieces.
[IMG
[IMG
[IMG
[IMG
[IMG
[IMG
1983 GPZ550
  • Tusch
26 Mar 2016 19:35
#717501
Nothing new really, got dinner at my buddy's house and mocked up the tank and seat. I'd like to do a bolt on subframe, possibly aluminum trellis.
[IMG
[IMG
[IMG
[IMG
[IMG
He's going to come by this week and drop off my bike and one of his for me to ride in the mean time. I'll start working on the tail and seat mating. I've got a parts bike frame to play with and I might start making a jig to create the new subframe from.
1983 GPZ550
  • motorscot
  • motorscot's Avatar
03 Dec 2016 16:44
#749391
I know it's been a while on this thread, but I've got a couple of questions.
I'm using 94-97 ZX9R front forks, and the front and rear wheels for my project. However, I ended up going with a 2008 ZX6R swingarm, which means my 95 9R rear wheel is a "no go" without machine work
I may swap to zx6r wheels, but I'm not sure if the front will drop into the zx9 forks
What is the width of the zx6r front wheel (rotor to rotor)?
What angle is the swingarm? or rather, what is the distance from the upper frame rail (seat pan horizontal) to the top of the shock?
Thanks,
Scott
