- Thank you received: 43
Phoenix Fighter
- 79MKII
- Love Them Kaws!
The Kaw List:
- kaw-a-holic
- Thank you received: 249
I am using the cable right now, it was slipping with the cable set up, I want it to work correctly with the cable before I try to switch to hydraulic. Sooooo. I took the clutch apart, Clearance on the clutch basket fingers was good so I left them alone. At first glance the metal discs looked good but in the sunlight I could see some slight varnishing, I used the orbital sander with 500 grit and gave both sides a once over, Cleaned them up, oiled everything and reinstalled, I have to say it made a noticeable difference on a trip around the block. Once the wife is off work I will take it for a longer ride. As always thank you for all the advice,swest wrote: Jon, I thought you were going back to the cable for a while.
As for the hydraulic clutch I will most likely leave it until this summer when it is to hot to ride. I have been waiting so long now that all I want to do is enjoy the bike. Again thank you all for the advice
Jon
1977 KZ1000a1
Mesa, AZ
Phoenix Fighter Project
- Thank you received: 2740
- Irish-Kawi
- Thank you received: 37
swest wrote: Know how you feel. I almost have everything I need for my swing arm mod. The sprocket is stuck in Fontana and I need to figure out how long the chain needs to be. The last thing I need is to tear it down and have it out of action even for a day. It has to be plug and play.
Hey Steve,
Just an FYI but if you know the right info you can already figure out your chain length by using this calculator, hope it helps you
www.rebelgears.com/chainlengthcalculator.html
Brett
All the gear all the time!
1985 Kawasaki GPz 750 (ZX750-A3) 15,000 original miles www.kzrider.com/forum/11-projects/601230...z750-refresh-project
Father - Husband - Bourbonr - Rider
- Kawboy74
- Thank you received: 52
Good luck with the balance of the build.
David
1974 Z1A As original as I could get it
'88 ZX750R braided lines, mostly original
KZ1000 project on the bench
Burlington,Ontario,Canada
- kaw-a-holic
Kawboy74 wrote: Hey Kaw, have been watching your thread for a while and have been living through your build. I installed a hydraulic setup on my 900 and would not go back unless an emergency. Your clutch package only needs .080" of play to operate and you are pushing against your clutch springs when you pull on the lever through the piston in the slave. Like a brake caliper, once you use the clutch, the piston will travel from fluid push until there is no stroke left in the master. When the lever is released, the piston will be pushed back by the clutch springs until the fluid equalizes in the line at the return location of the master piston. Unlike a caliper that only uses rocking the action of the piston seal, most slave pistons have a spring mounted on the back to hold it from totally bottoming out in the housing. If you initially leave play between the slave piston and the actuator rod, as soon as you apply the clutch, the piston will take up any slack which to a very small degree will lower the fluid in your master cup. I would set up the rod length with the piston in the slave just recessed in the slave housing so the dirt and crap around that chain area does not tend to get any further into the slave than necessary.
David
Fantastic info, thank you David. Out of curiosity, what slave cylinder did you use?
Jon
1977 KZ1000a1
Mesa, AZ
- kaw-a-holic
Jon
1977 KZ1000a1
Mesa, AZ
- Thank you received: 797
but as a machinist and fabricator i get into some stuff i wouldn't normally do for myself :whistle: .
i currently have one such case of modding a pmfr outboard support to use a
i had to slot the mounting holes on the slave and bore the hole open to match the slave body but it was a straightforward deal.
here you can see the slotting that had to happen.
thanks to Kawboy74 for his information sharing.
- Kawboy74
I will try and post a picture of the newer plate tomorrow night.
- kaw-a-holic
Still waiting on the triple. I told my brother he needed to get the design done so we could print it out to prototype. Once that is done in will pay someone to machine it so I can get them done.swest wrote: Glad to hear you're able to start riding the bike. Did you get some extensions for the forks or are you still waiting on some trees? Can you get some clips. Love to see them.
Jon
1977 KZ1000a1
Mesa, AZ
