- Thank you received: 249
Phoenix Fighter
- kaw-a-holic
swest wrote: Sounds good. Will you have some plastic mock ups to test sizing? MAN it's got to cost a bundle. If it weren't for that, I was thinking you could beef up around the top and use those extenders. I'm sure it's better the way you're doing it. Like to see pics of the progress.
Question; Weren't the early Honda top triple clamps sand cast? I read they did that until they knew if the bikes would sell or not then the tooled up molds. That's why I suggested casting the top clamp.
Sandcasting might be alright if the triple was flat but with the nearly 2" of drop I need all the strength I can get. The cost will only be in materials as i am getting the drawing and tooling labor for free.
As for the proto type, yes, there will be a 3D printed version first for fitment. I may have someone else mill it the first time as my brother wants to mill it in his garage but I would have to wait a few months. I don't want to wait months to get on the bike as that would put me in the Arizona summer. I may just turn a couple of fork tube extenders in the lath to get me by.
Jon
1977 KZ1000a1
Mesa, AZ
Phoenix Fighter Project
- Thank you received: 2740
- kaw-a-holic
swest wrote: That's a good plan my friend. Maybe a couple sleeves to go on the outsides of the tubes for more strength. That way you can enjoy all the hard work you have into it.
With a pinch bolt on the bottom
Jon
1977 KZ1000a1
Mesa, AZ
- kaw-a-holic
Jon
1977 KZ1000a1
Mesa, AZ
- kaw-a-holic
swest wrote: Are they in the front end you were planning on using? Cool
No, it's a bearing conversion kit from All Balls Bearings and the GSXR stem. That is why I went with this front end, at the time I didn't want to do machine work. I have learned a lot building this bike.
Jon
1977 KZ1000a1
Mesa, AZ
- spdygon
- Thank you received: 117
I'm using all balls conversion bearing kit
1978 Kz1000 Z1R. 10K Miles1
1978 kz1000 z1r 27k miles
1976 Kz900A4 (Red)21K miles
1976 Kz900A4 ( Red)7500 miles
1974 Z1 900 project
- kaw-a-holic
spdygon wrote: I'm using same forks as you...93 gsxr1100 forks . When I mock up mine ( see sig pic) I had almost 4" clearance with the exhaust on.
Mine are 92 GSXR 750's, I have been told the 1100's were longer.
Jon
1977 KZ1000a1
Mesa, AZ
- kaw-a-holic
Do you, or anyone else know if 91-92 GSXR forks are longer than the 750's?
Jon
1977 KZ1000a1
Mesa, AZ
- davido
- Thank you received: 292
That is not a lot and (for me) not enough.
I was talking with my local bike shop owner about this today. Fork extensions or dropped triple tree? Im still undecided.With fork extensions,you have a weak spot,with dropped upper yoke you have a weak area,unless you drop the bottom yoke as well,in which case you have an empty bank account!For the money,he reckoned the extensions would be good enough.
I was also thinking about heavier springs in the forks but he thought that wouldnt work because the springs are rated to the weight of the bike. I pointed out that the ZXR springs (in your case GSXR springs) would be rated to the weight of a ZXR (GSXR) which would be a lot lighter than a 1980s KZ so,it should be possible to fit heavier springs without losing effectiveness in the front suspension (probably improving it). Heavier springs would,in theory, lift the front end,though I dont know by how much.Then again,every little bit helps!
Im just running this around in my mind at the minute as I have a ton of other things to sort out first but I need to sit down and figure this all out. First thing is to set up the sag properly ,as the bike is.Take some proper measurements and go from there.
CB550 (1978)
CB500/4 (1972)*
KZ1000CSR (1981)
XT 600E (1999)
TDM900 (2003)
