- Thank you received: 249
Phoenix Fighter
- kaw-a-holic
DoctoRot wrote:
kaw-a-holic wrote:
They are running really rich. Les Holt told me they would be ridable, they are. You have to roll on the throttle. I met a guy here in Mesa that has been restoring and modifying KZs since they were new on the show room floor. We talked for a bit. He said that through dyno testing that the best all around performance he found was running BS34s with a stage 3 dyna jet kit. It's worth looking into. As for the forks. I think the best bet will be a custom triple with a 2" drop. If I'm going to go that far I might as well do a new bottom tree also so I can move the forks forward about an 1" to gain back some turning radius.swest wrote: What makes you say the carbs are too big?
adding and inch of fork offset is a lot. even a couple mm can have a big effect on handling. Not sure what your trail numbers are now but that much offset increase could easily put you in dangerous tank slapping territory. You're in good hands with Les, but i would for sure run down your geometry numbers before you commit to any custom triple dimensions
I just threw the number out there. I will have to do some research to see determine trail and rake numbers. I k ow I have seen it on here before.
Jon
1977 KZ1000a1
Mesa, AZ
Phoenix Fighter Project
- Thank you received: 2740
- les holt
- Thank you received: 288
I'm going to make a youtube video on measuring forks to order trees, that may be one of the 1st things I do after I get moved into shop.
Les
- Thank you received: 797
- kaw-a-holic
531blackbanshee wrote: some cases these may help.
Thanks Leon I looked into these a while back but they won't work for a 98 GSXR 750 I think due to the adjuster on the top.
Jon
1977 KZ1000a1
Mesa, AZ
- kaw-a-holic
swest wrote: Something to look at.
jetsrus.com/carburetor/carb_mikuni_RS_ca...oded_view_parts.html
jetsrus.com/a_jets_by_carburetor_type/je...ni_BS_30-97_air.html
jetsrus.com/a_jets_by_carburetor_type/needlejet_jets_mikuni.htm
Thanks Steve, I actually have a Sudco 5th Edition Tuning Manual
Jon
1977 KZ1000a1
Mesa, AZ
- davido
- Thank you received: 292
CB550 (1978)
CB500/4 (1972)*
KZ1000CSR (1981)
XT 600E (1999)
TDM900 (2003)
- kaw-a-holic
davido wrote: Found these advertised locally. Euro150 a pair. Just emailed him to check if he has a set to fit the ZXR and how long they are. If youre interested ,ill ask for your bike. (Model/year??).
That would be great I am using 1998 Suzuki GSXR 750 Showa forks.
Jon
1977 KZ1000a1
Mesa, AZ
- StreetfighterKz
- Thank you received: 117
kaw-a-holic wrote: That would be great I am using 1998 Suzuki GSXR 750 Showa forks.
Double check your years before spending $$.. '96+ Gsxr750's have a 25mm axle, no speedo drive and flat brake rotors. I think you have a '93-95 Gsxr750 front end.
Later, Doug
1978 z1000 Streetfighter
1976 z900 Stripfighter (work in progress)
1983 Gpz750 Resto-Mod
1989 Vmax
- StreetfighterKz
Later, Doug
1989 Vmax
