- Thank you received: 249
Phoenix Fighter
- kaw-a-holic
Jon
1977 KZ1000a1
Mesa, AZ
Phoenix Fighter Project
- Thank you received: 2740
- kaw-a-holic
Jon
1977 KZ1000a1
Mesa, AZ
- kaw-a-holic
The master cylinder is huge and brand new so it should not be the issue. If I take the master off the push rod it will extend but only a 1/4" at a time. Not sure where to start other than to buy a new one or just pay for the conversion sold on Z1
So of course the bike is still not streetable. I am switching back to the cable drive for now.
Jon
1977 KZ1000a1
Mesa, AZ
- davido
- Thank you received: 292
(Mine is still in bits. Still havent solved the stripped thread on the casing.)
CB550 (1978)
CB500/4 (1972)*
KZ1000CSR (1981)
XT 600E (1999)
TDM900 (2003)
- kaw-a-holic
davido wrote: Bummer. Sorry to here that. Any idea whats the problem? Is the resevoir big/small enough? Is it a problem with the spacing?
No idea, at this point I don't know how much money I am willing to sink into it. I used a Slave Cylinder off of a Suzuki 1000 because it was 2 bolts. Not sure if it is the Master Cylinder or the slave. M.C. is brand new and certainly big enough. For now it is going back to cable operation so I can get some ride time in. Although, we are getting a crap ton of rain this winter in Arizona. Better than snow I guess.
I was hoping you had yours done.
Jon
1977 KZ1000a1
Mesa, AZ
- davido
Anyway,if it works in the same way as a hydraulic brake,then the master and slave need to match.Mine should be ok as theyre both from the same ZXR but you have different parts . Maybe the master is too big,giving less pressure? (or is it the other way around??) Could you find/borrow one from a Suzuki 1000 Just to try It,see what happens?
CB550 (1978)
CB500/4 (1972)*
KZ1000CSR (1981)
XT 600E (1999)
TDM900 (2003)
- floivanus
- Thank you received: 116
10-12mm seems normal ish for conversions
Past; 78 kz1000, 83 kz550
Andrew
- 79MKII
- Love Them Kaws!
- Thank you received: 43
Hopefully it's a bleeding issue...maybe air in the lines?
The Kaw List:
Cold and windy here. Supposed to be back in the 80's in a couple days. Crazy desert weather. :S
