- Thank you received: 15
Phoenix Fighter
- Shimmy
americanclassix.com/kawa_improvements.html
It looks similar to the one pictured in the last link davido posted above.
1980 KZ750 LTD
Edmonton, Alberta
- Thank you received: 2740
- kaw-a-holic
- Thank you received: 249
davido wrote: Heres a nice looking one. Cheap as chips as well.
www.dgchassis.net/Dragbike%20parts/dragbike-parts.aspx
Also
pmfr.com/clutch-release-kits/clutch-release-kits
and heres a link to some info if you want to use the original cover (Steve)
www.z1ownersclub.co.uk/forum/viewtopic.p...ic+clutch+conversion
$75 from D&J ? I may have to take the easy way out. Thanks for the links Davido.
Jon
1977 KZ1000a1
Mesa, AZ
Phoenix Fighter Project
- Thank you received: 797
your under tray and m-unit/elec.mounting is very sanitary looking.
them switches is nice too .
- 79MKII
- Love Them Kaws!
- Thank you received: 43
The Kaw List:
- kaw-a-holic
79MKII wrote: The D&G clutch release cover is for the stock mechanism....does not include a slave cylinder or any way to mount one. Would probably be pretty easy to modify though. I like the PMFR a little better for $80....the bolts are countersunk and look a lot better IMHO. I have both brands....PMFR wasn't available for a long time during a change of ownership. Looks like they're back up and running now.
Thanks for the heads up. Is the PMFR also for using the stock worm drive or will it accept a slave cylinder?
Jon
1977 KZ1000a1
Mesa, AZ
- kaw-a-holic
Little by little it's getting there.531blackbanshee wrote: :woohoo: $75.00 is freakin cheap !
Jon
1977 KZ1000a1
Mesa, AZ
- kaw-a-holic
Jon
1977 KZ1000a1
Mesa, AZ
- kaw-a-holic
swest wrote: This is going to sound weird but you can use the beer can trick to shim up your cams and take your readings, then remove the shims from under the bearings. Be sure to shim the cam towers too. Measure the thickness of the can stock and subtract. I'll be back later, late to work.
I'm not quite following you Steve, can you break that process down a bit for me please.
Jon
1977 KZ1000a1
Mesa, AZ
- 79MKII
- Love Them Kaws!
Yes, PMFR is also for the stock set up.
The Kaw List:
