- Thank you received: 43
Phoenix Fighter
- 79MKII
- Love Them Kaws!
The Kaw List:
- kaw-a-holic
- Thank you received: 249
79MKII wrote:
I'm having this same concern right now myself. I have an M6 thread that I'd like to heli-coil but fine thread heli-coils are supposed to use that pre-coiler or whatever they call it. The hole is where a knock pin goes, so it's basically countersunk....can't get that tool in there. These can be wound in by hand? Is that what you guys are saying? I wanted to try it but once it's drilled, there's no turning back. You weren't able to install the heli-coil without removing the head, were you?kaw-a-holic wrote: ... It was really easy. was concerned about it working at since I couldn't use the applicator to get the Helicoil in the hole due to the shoulder. Just like you said Steve. ...
Took the head off, left the cylinders on. I used just the threaded rod that cam in the kit. Trust me it didn't just go in. I held it as straight as I could applied downward pressure, turned and hoped for the best. I didn't have anything to loose. The old threads were wasted,
Worse case is I would have just tapped it and ran a bigger bolt.
Jon
1977 KZ1000a1
Mesa, AZ
Phoenix Fighter Project
- kaw-a-holic
Hey! Now I can get my crank welded. Do I need to ship this to an expert? OMR if you are reading this have you had any cranks welded in AZ?
Jon
1977 KZ1000a1
Mesa, AZ
- Thank you received: 2740
A tap is self centering more or less. As long as it goes in straight and you stop when too much resistance is felt, back off a little, and cut some more, it will turn out well. A little oil helps prevent galling of the threads. I always use oil when drilling or tapping threads.
- kaw-a-holic
Jon
1977 KZ1000a1
Mesa, AZ
- missionkz
A fear grossly exaggerated by the uninitiatedkaw-a-holic wrote: I'm going to pull the cylinders back off and do a double check, I really don't want to pull the cases. I am not sure I can get it all back together. The transmission is what really makes me apprehensive about splitting the cases.
Bruce
1977 KZ1000A1
2016 Triumph T120 Bonneville
- floivanus
- Thank you received: 116
Past; 78 kz1000, 83 kz550
Andrew
- kaw-a-holic
Jon
1977 KZ1000a1
Mesa, AZ
- floivanus
You may also want to check the small shift fork rod, theyre supposedly easy to bend and the later 77 and early 78 I had someone did a poor job cutting the circlip groove at the end of the shaft. Which made it so the shaft could slip and trash 2nd gear on me.
Andrew
