- Thank you received: 43
Phoenix Fighter
- 79MKII
- Love Them Kaws!
The Kaw List:
- kaw-a-holic
- Thank you received: 249
Jon
1977 KZ1000a1
Mesa, AZ
Phoenix Fighter Project
- kaw-a-holic
A sneak peek of the exhaust on.
Will make a bracket that goes from the back of my rear set to the bung on the slip-on.
Jon
1977 KZ1000a1
Mesa, AZ
- Thank you received: 2740
- kaw-a-holic
swest wrote: Where did you buy the kit and how much? Get it done Reb, I want to nominate it for BOTM. :woohoo:
The kit was $40 at O'Rielly Auto Parts. It was really easy. was concerned about it working at since I couldn't use the applicator to get the Helicoil in the hole due to the shoulder. Just like you said Steve.
She is a distant beauty Steve, not sure she is worthy of BOTM. There are so many phenomenal bikes built on this site. I am building it to be a daily rider no trailer queens in my garage.
Enough chit chat I need to go get to work!
Jon
1977 KZ1000a1
Mesa, AZ
I've fixed other bolts like the pinch bolt on my top triple tree. No meat for time certs.
Good job.
- Thank you received: 797
freshly stripped= helicoil
helicoil stripped= stepped stud or timesert
timesert/stepped stud stripped=weld and remachine
hth someone,
- 79MKII
- Love Them Kaws!
I'm having this same concern right now myself. I have an M6 thread that I'd like to heli-coil but fine thread heli-coils are supposed to use that pre-coiler or whatever they call it. The hole is where a knock pin goes, so it's basically countersunk....can't get that tool in there. These can be wound in by hand? Is that what you guys are saying? I wanted to try it but once it's drilled, there's no turning back. You weren't able to install the heli-coil without removing the head, were you?kaw-a-holic wrote: ... It was really easy. was concerned about it working at since I couldn't use the applicator to get the Helicoil in the hole due to the shoulder. Just like you said Steve. ...
The Kaw List:
- davido
- Thank you received: 292
531blackbanshee wrote: fwiw here is the way i determine how to repair stripped threads.
hth someone,
So whats the difference twixt a Helicoil and a Timesert?
CB550 (1978)
CB500/4 (1972)*
KZ1000CSR (1981)
XT 600E (1999)
TDM900 (2003)
- Thank you received: 2829
Attachment 00003s.jpg not found
I don't use the drill bit. The hole is large enough. Getting the tap past the insert (pin) is a problem. On my triple clamp I had to drill where the non threaded part is slightly to get the tap in there and the coil. It was tricky and I munged up one but I did it. Yes you can just use a ling small screw driver going back and forth little by little until set. Try not to bust the little tang off.
