KZ1000ST customize project
- bassie10
Re: KZ1000ST customize project
08 Aug 2014 13:58
thanks.. I try to keep most of the ST looks, and still do a little customizing and upgrading.
- bassie10
09 Aug 2014 11:53
brand new inner fender..
Attachment DSC_0283.jpg not found
- bassie10
09 Aug 2014 11:55
and just so you know, it's going to be a..
Attachment DSC_0288.jpg not found
- bassie10
10 Aug 2014 09:14 - 10 Aug 2014 09:16
The new bearings seem to build up a little higher, not much thread left for the upper stem nut..
The lower stem nut is much thicker than the upper, about 3 threads, so I think the solution would be to take a few threads of the lower nut to make room for the upper one.. I guess that will still be strong enough?
Attachment DSC_0297.jpg not found
Last edit: 10 Aug 2014 09:16 by bassie10.
11 Aug 2014 08:03
you can thin that down like you want,no worries.
- bassie10
04 Jan 2015 10:58 - 04 Jan 2015 11:03
just a small update.. paint and 2K clearcoat on the headlight bucket and front legs.. almost ready to put the wheels back in and make her roll again.
Attachment DSC_0333.jpg not found
Attachment DSC_0326.jpg not found
Last edit: 04 Jan 2015 11:03 by bassie10.
- ed spangler
- Tennessee Z
04 Jan 2015 12:22
Very Nice!!
Have 1975 Kawasaki Z1-B & 2003 Harley Davidson Heritage Softail Classic
Had Hondas, Harleys and many ,many Z Series Kaws both Std. & LTD's
The following user(s) said Thank You: bassie10
Re: KZ1000ST costumize project
04 Jan 2015 12:54bassie10 wrote:Attachment DSC_0054_2013-11-10.jpg not found
first problem, see other topic.... leave as is, or to be tackled later on..
What did you do about the shorn counter shaft bolt>
- bassie10
04 Jan 2015 13:36 - 04 Jan 2015 13:40
nothing... i'm convinced it will not be a problem as it did not before, and by someone in another topic i started on the subject telling me it's a common thing and never gives a problem.. enough said about it for me..
besides, i have my eye on another engine that has a good chance of going in.
Last edit: 04 Jan 2015 13:40 by bassie10.
