Kz440 resurrections
  • flint
  • flint's Avatar Topic Author
Re: Kz440 resurrections
13 Oct 2013 01:01 - 13 Oct 2013 01:16
#609816
Attachment 035.JPG not found
one piece at a time
1980 kz440 ltd a-1 (bobber thing)
1980 kz440 d-1 (stripped down scooter)
Last edit: 13 Oct 2013 01:16 by flint.
  • flint
13 Oct 2013 01:01 - 13 Oct 2013 01:21
#609817
Attachment 005.JPG not found
Here's to the build!
one piece at a time
Last edit: 13 Oct 2013 01:21 by flint.
  • flint
13 Oct 2013 01:11
#609818
Attachment 037.JPG not found
this will be awesome
one piece at a time
  • flint
14 Oct 2013 12:01
#609962
Attachment image_2013-10-14.jpg not found
Black grips and have the master cylinder for the front brake in some acid to get rid of the red color. Now to install the side panels and make an awesome seat for this little beastro. Almost there just in time for winter! Yes!
one piece at a time
14 Oct 2013 12:18
#609963
flint wrote: ...have the master cylinder for the front brake in some acid to get rid of the red color....
Acid may be harmful to surface of the piston bore.
Would consider thoroughly rinsing off all the acid, and soaking the master cyinder in "brake fluid" to remove the red color (presumably some type of paint).
Good Fortune! :)
  • Nebr_Rex
  • Nebr_Rex's Avatar
14 Oct 2013 13:03
#609968
Acid is also harm full to aluminum. Try Pinesol,just a touch of acid.
It cleaned cases and carbs really well. Should work on an aluminum
master cylinder.
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
  • flint
14 Oct 2013 13:48
#609975
Should've worded better. Just the cap for the brake fluid reservoir. And the little bracket. And the "acid" is aluminum wheel cleaner. So just to take the paint off with baking soda on stand by to stop that stuff.
one piece at a time
  • flint
30 Oct 2013 14:19
#611627
Got the frame cleaned up. And the motor in. Jumped the starter to make sure everything is kosher before hand. Made the seat pan and it looks iffy now but, when the foam is on there she'll be pretty. Should be done in a few. Approx 45 hours.
Attachment image_2013-10-30.jpg not found
Attachment image_2013-10-30-2.jpg not found
one piece at a time
  • flint
30 Oct 2013 14:21
#611628
And as always sideways.
one piece at a time
  • flint
10 Nov 2013 10:29
#612711
Started the bike after getting the starter and coil energized. The bike started right up and stayed running smooth. I let it run for about 5 minutes then checked the new spark plugs and they look identical and rich as all get out. So I need to tune the main jet and get it dialed in. The motor hasn't ran in about a decade so it was stinky like a burnt up rats nest just got blown out of the exhaust. I am way to excited about it and that carb makes for crisp feel on the motor even though it runs like a dog at the moment. I also elected to put a bump stop seat on the bike and putting all electrics in there with a anti gravity battery I use at work for the wind turbines. (Yes I get permission to use them).
Attachment image_2013-11-10.jpg not found
one piece at a time
  • flint
12 Nov 2013 09:01 - 12 Nov 2013 09:04
#612875
BUMP STOP! FYI fiberglass resin and cloth is kind of a mess. By mess I mean Christmas vacation tree sap. I need to figure out how to get the battery in there but, that'll be some other day. That seat makes it look a big meaner then the original idea. (And yes she'll be getting proper exhaust and a uni air filter)
one piece at a time
Last edit: 12 Nov 2013 09:04 by flint. Reason: Photo upside down.
  • KowalskiCW
  • KowalskiCW's Avatar
12 Nov 2013 09:38
#612878
I'm diggin the seat. Good use of the frame shape!
The following user(s) said Thank You: flint
