My KZ650 Turbo Build
  • jeffasaki
  • jeffasaki's Avatar
Re: My KZ650 Turbo Build
09 Aug 2013 04:13
#600557
if you ever take a 750 turbo motor out of a 750 tubo bike
and put it in a old kz 650 frame
I WILL FIND YOU AND MAKE YOU PUT IT BACK WHERE IT CAME FROM
just saying that a stock 750 turbo is way worth more then a modded kz 650
always make the stock turbo
kz 650 = little girl bike
78 Z1R
78 KZ1000
76 KH500 gone
71 HS1B 90
81 GS 1100 gone
80 PE400
02 KLR
Ontario Canada
  • D.Nel928
  • D.Nel928's Avatar Topic Author
09 Aug 2013 10:52
#600579
jeffasaki wrote: if you ever take a 750 turbo motor out of a 750 tubo bike
I really wanna buy a 750 turbo motor in spite of this comment, lol. 2 on ebay for sub $1k, almost a better deal.
'78 KZ650 Custom thingy turned turbo build
www.kzrider.com/forum/11-projects/520339...z650-fighter-project
  • 531blackbanshee
  • 531blackbanshee's Avatar
  • Vendor
  • Vendor
09 Aug 2013 10:56 - 09 Aug 2013 10:57
#600581
jeff is from canada :whistle: ,
they'll prolly smell the weed and alcohol on him at the border !
even if he does get across he prolly won't be able to find you :laugh: !
and if he does :pinch: ,
your turbo 650 will weigh less than his turbo gpz so you can just out run him :woohoo: !!!!!!!!
Last edit: 09 Aug 2013 10:57 by 531blackbanshee.
  • 531blackbanshee
  • Vendor
  • Vendor
09 Aug 2013 11:00 - 09 Aug 2013 11:00
#600582
if you buy it from ebay you wont be the one taking it out of the bike :whistle: .
so he can take his issue up with the seller :laugh: !!!!!!!!!!!
Last edit: 09 Aug 2013 11:00 by 531blackbanshee.
  • jeffasaki
09 Aug 2013 11:40
#600587
531blackbanshee wrote: jeff is from canada :whistle: ,
I love you man B)
78 Z1R
78 KZ1000
76 KH500 gone
71 HS1B 90
81 GS 1100 gone
80 PE400
02 KLR
Ontario Canada
  • 531blackbanshee
  • Vendor
  • Vendor
09 Aug 2013 15:32
#600604
I love you man B)
i have enjoyed many laughs from your post's sir :P .
keep up the good work :evil: .
  • D.Nel928
12 Aug 2013 18:11
#601053
Got my GPZ750 Turbo rods in today, can't say I'm not disappointed here. I figured there would be a bit more difference. I know the wrist pin is bigger, and the rod bolts are beefier. Hopefully there is a metallurgical difference between the two, because a 1mm bigger wrist pin doesn't justify the money imho. But who cares, I paid $200 and I've seen the rods go well past my power goals. Forged slugs coming soon!
Turbo rod on the left.
[img
KZ750 Rods by Dennis Nelson Photography , on Flickr
  • les holt
  • les holt's Avatar
  • Vendor
  • Vendor
12 Aug 2013 18:51
#601059
Between the rod bolts and some minor differences, lots of parts laying on the ground! Do not be disappointed! You would be supprised at the differences in the prep work before the bolts and wrist pin size. Ask any ole hot rodder about the chevy pink rods. Heat treatment, shot peening just to mention some of the cool stuff used today that was played with 30 plus or more years ago.
Les
  • koolaid_kid
  • koolaid_kid's Avatar
12 Aug 2013 19:33
#601064
Don't forget magnafluxing to detect flaws and minor cracks. All these things make for a much stronger than a stock rod.
1983 GPz 750
810 Wiseco, Kerker, K&N, DynoJet S3, Accel, Progressive, etc.
  • koolaid_kid
12 Aug 2013 19:42
#601065
D.Nel928 wrote: My biggest problem up until now is oil scavenging from the turbo. Will the 750 turbo pump fit on the 650 case? Any other ideas?
Edit: Found this dude, would probably do the job. Only problem is the $399 price tag!
[img
Exa-Pump by Dennis Nelson Photography , on Flickr
This is an awesome pump, I looked at it when I turbo'd my TransAm. I wonder if it has too much capacity for a motorcycle engine?
You might be better served by their mini model:
Exa-Pump mini
No cost savings, unfortunately.
1983 GPz 750
  • D.Nel928
12 Aug 2013 19:46 - 12 Aug 2013 19:47
#601066
I will be going with the mini actually. Turbowerx said the standard would be fine, but I like the smaller size of the mini. Kind of a bummer on the price tho :( The standard has 10,000 hour brushes in it, and the mini are only rated for 2,000. Thankfully when they do need replaced it is a very simple process.
Last edit: 12 Aug 2013 19:47 by D.Nel928.
  • les holt
  • les holt's Avatar
  • Vendor
  • Vendor
12 Aug 2013 21:06
#601079
figure 2,000 hours at only 10 mile per hour average, tally's up to 20,000 mile. Not bad!
Les
