1982 KZ1100A-2 Shaft LTD by Vetter Cafe/bobber
- rokit_armor
Re: 1982 KZ1100A-2 Shaft LTD by Vetter Cafe/bobber
20 Dec 2014 19:54
So close I can smell it!
All electrical works fine, aside from two bulbs that need replaced in the instrument cluster. Also can't check the speedo yet haha. Brakes are done. Just down to tuning the carbs, and finding another swingarm pivot bolt. Theres four spare ones in salvage bikes at the shop, but they had a go at it for a few hours, and finally let me have a go at them too. 6 stripped screws and a broken hammer later I gave up.
- rokit_armor
12 Jun 2015 19:34
Time to dig this thread out of the archives, lol
Back from the shop, completely roadworthy! Turns out some pin in the timing advance was all messed up, causing it to be 1/2" off. Timing was fine at idle, but when the advance kicked it, well pffbbbtttbbb. They also jetted the carb correctly(I wasn't too far off, with the advance working right). She's got some balls lemmetellya.
If you look close, my speedo is bouncing all over the place upon acceleration and deceleration. Steady speeds and it reads correct. Any ideas?
- rokit_armor
12 Jun 2015 19:47
I just put my phone in my shirt pocket to shoot this video, helmet cam to come soon. Doesn't seem like it's going very fast when all you see is the road and tank
- medic455
27 Jun 2015 16:38
Loving that red frame and carbs! Giving me some Ideas for my Spectre.
Do what is right, do what is necessary. Everything else is negotiable.
- rokit_armor
30 Jun 2016 18:02
Did some more upgrades to the bike while the motor was out. Cut off the old turn signal tabs, exhaust tabs, removed the rear fender and old tail light. Going to do a solo seat on it now.
- rokit_armor
- rokit_armor
23 Sep 2016 18:42
Been tinkering with the bike some. Rebuilt the forks with new springs, seals, and oil. Painted the lower forks satin black. Clip on bars, stacked projector headlamp, new hydraulic masters for clutch and brake (doing a hydraulic clutch conversion). Pistons finally came, and started on the solo tail piece.
- BLOODYJACK2
Re: 1982 KZ1100A-2 Shaft LTD by Vettel Cafe/bobber
14 Dec 2016 08:58
What shocks did you end up using I need some for my shaft drive KZ1000
- rokit_armor
20 Jan 2017 01:53
Sorry bud, I'm not sure, it was so long ago. I think they were just some ones I found on Ebay.
Did a few more touches, including motor paint.
- Zen Shenron
20 Jan 2017 17:04
Do you happen to still have the vetter mounting hardware? I have a couple of old fairings but looking for the brackets.
Charles
1980 GS850Gl
1981 KZ1100 A-1
1982 KZ1100 A-2
All Shafties
1980 GS850Gl
1981 KZ1100 A-1
1982 KZ1100 A-2
All Shafties
The following user(s) said Thank You: JR
- rokit_armor
08 Feb 2017 11:52
Vetter stuff is long gone, sorry.
More progress, slowly but surely.
Mostly machine work on the head and block, brake lines, and shift linkage left.
Should be ready late spring.
- Zen Shenron
08 Feb 2017 15:19
Such a beautiful bike, I love it.
Keep the pics coming.
Charles
1980 GS850Gl
1981 KZ1100 A-1
1982 KZ1100 A-2
All Shafties
1980 GS850Gl
1981 KZ1100 A-1
1982 KZ1100 A-2
All Shafties
