my 650csr's transformation to the "RAT RACER"
  • CrazyDuck
  • CrazyDuck's Avatar
Re: my 650csr's transformation to the "RAT RACER"
14 Mar 2013 00:44
#576887
Good god. I have never seen a set of forks leak THAT much before.
1976 KZ900
1974 TX500
1978 TT500
2007 Aprilia SXV
14 Mar 2013 01:04
#576892
Some youtube videos available by searching KZ650 fork seals
Also see this technique, but never tried it.
Good Fortune! :)
  • jbalet666
  • jbalet666's Avatar Topic Author
14 Mar 2013 14:25
#576934
CrazyDuck wrote: Good god. I have never seen a set of forks leak THAT much before.
Yeah I know its kinda weird that it only stated leaking at the shop......hmmmm makes you wonder
81 650csr
AoA
old soul young blood
  • donthaveakawman
  • donthaveakawman's Avatar
14 Mar 2013 15:17
#576937
curious about gpz forks with the anti-dive unit for the brakes
  • martin_csr
  • martin_csr's Avatar
Re: -
14 Mar 2013 18:02 - 18 Mar 2013 13:49
#576959
Last edit: 18 Mar 2013 13:49 by martin_csr.
  • jbalet666
14 Mar 2013 19:56
#576972
martin_csr wrote: Install seals that are made in Japan, such as K&L - not sure what Z1Enterprises sells now.
Some dealers apparently install cheap aftermarket seals (ie, made in china etc).
After rebuilding the forks, air them up to ~8 psi w the front wheel off the ground... the useable range is ~7.5-14 psi or thereabouts. Use a low pressure gauge, not a typical tire gauge. Do not air them up to the max listed on the forks.
Ok I'll look around I was origonaly going to get them there any other suggestions?
What fork fluid should I use?
And what do I use to air up.the fork?
81 650csr
AoA
  • martin_csr
Re: -
14 Mar 2013 22:21 - 18 Mar 2013 13:48
#576983
Last edit: 18 Mar 2013 13:48 by martin_csr.
  • jbalet666
14 Mar 2013 22:29
#576984
martin_csr wrote: A bicycle pump works. 10W fork oil is specified, but 15W might be preferable.
Use an air impact gun & a hardened 8mm socket allen to remove the bottom allen bolts. You may have to heat them w a propane torch. If they're stuck &/or the inner cylinder (damper rod) spins w the allen bolt, then you'll need to make a tool to keep it from spinning. The head of the damper rod looks just like a 19mm socket. I used a short 1/2" left-hand-threaded bolt w nuts (a 1/2" bolt has a 3/4" head which ~=19mm).
Awesome help
Thanks a lot
One more question and I know its probably very remedial but.I'm.assuming you need to relieve the pressure from the for first correct
81 650csr
AoA
  • martin_csr
15 Mar 2013 16:46 - 10 Apr 2013 14:19
#577076
Last edit: 10 Apr 2013 14:19 by martin_csr.
  • jbalet666
15 Mar 2013 17:55
#577082
martin_csr wrote: Yes, relieve the air pressure. Also, you could try draining them by removing the drain screw at the bottom, but it seems easier to remove the top caps & dump out the oil. I dumped it out without removing the innards, then poured in some lacquer thinner, inverted a few times, then dumped that out & proceeded w the disassembly. It's a messy job but the solvent makes it less so.
Yeah I ordered the parts so once they get here I'll try it
81 650csr
AoA
  • jbalet666
10 Apr 2013 12:43
#581611
well disassembly went smoothly as well as the replacement of the fork seals
quick question:
whats the exact amount of fluid required i have the clymer book but its not csr specific i dont want to put less and wear out my forks
81 650csr
AoA
10 Apr 2013 13:55
#581629
Including information about bike year and model is helpful to viewers and usually elicits better responses.
It's easy to put the information in your signature where it shows in all posted messages, past and future.
And may be changed whenever and as often as desired.
If wanting a signature showing information about the bike in posted messages, it's easy to do. Here's how:
Attachment addsig.jpg not found
Good Fortune! :)
