my 650csr's transformation to the "RAT RACER"
  • Steely
  • Steely's Avatar
Re: my 650csr's transformation to the "RAT RACER"
10 Mar 2013 23:56
#576455
honestly i half assed it lol process was couple coats of primer. then a bunch of coats of color. more the better. you dont want to accidentally sand threw the color into the primer. sand the color a bit just to smooth it out. i used 320. then i sprayed an even coat of black not to thick not too thin. then wet sanded through the black. i think i used 320 again. then i sprayed clear clear clear clear sand and buff
  • jbalet666
  • jbalet666's Avatar Topic Author
11 Mar 2013 00:21
#576458
nice and simple hahaha
im thinking about doing maybe a silver with root beer top coat that or brass/copper with a root beer top coat
thanks for the help seat should be here next month so im chomping at the bit already
81 650csr
AoA
old soul young blood
  • Steely
  • Steely's Avatar
13 Mar 2013 01:56
#576768
the seat is actually black but it comes out grey with flash
  • jbalet666
13 Mar 2013 03:20 - 13 Mar 2013 03:22
#576774
That looks awesome what are you using for the seats padding?
81 650csr
AoA
Last edit: 13 Mar 2013 03:22 by jbalet666.
  • Steely
  • Steely's Avatar
13 Mar 2013 08:38
#576781
It's 1 inch pad from airtech. It's a little pricey but I like it so far. You have to cut and shape it yourself with different grades of sandpaper to get it nice. And you probably won't need 1 inch like I did
  • jbalet666
13 Mar 2013 15:37
#576833
Steely wrote: It's 1 inch pad from airtech. It's a little pricey but I like it so far. You have to cut and shape it yourself with different grades of sandpaper to get it nice. And you probably won't need 1 inch like I did
Yeah I've been playing around with the idea of using one of those foam shop mats or maybe some memory foam so I can get the most comfort from the least amount of material or money hahah
81 650csr
AoA
  • jbalet666
13 Mar 2013 15:44 - 13 Mar 2013 15:46
#576835
So the bike has been working fine.....
Until a couple of days ago
I'll let the pictures explain
Attachment 2013-03-13_11-06-14_658.jpg not found
What is that liquid you might say?
Attachment 2013-03-13_11-05-49_4.jpg not found
Why would it be here you might ask
Well here's a pretty big clue
Attachment 2013-03-13_11-05-28_450.jpg not found
Attachment 2013-03-13_11-05-23_613.jpg not found
So next week my seals shall be replaced as well as the fluid and hopefully *knock on wood* she will be happy and stop throwing fits for awhile
81 650csr
AoA
Last edit: 13 Mar 2013 15:46 by jbalet666.
13 Mar 2013 16:10
#576840
If an oil cooler is fitted, a leaking oil cooler hose -- perhaps loose attachment or fitting -- can also create a mess.
Good Fortune! :)
  • jbalet666
13 Mar 2013 16:15
#576841
Patton wrote: If an oil cooler is fitted, a leaking oil cooler hose -- perhaps loose attachment or fitting -- can also create a mess.
Good Fortune! :)
Nope there's puddles underneath my forks Hahaha
81 650csr
AoA
  • DesertKZ
  • DesertKZ's Avatar
13 Mar 2013 17:28
#576847
Ugh, I have to redo one of mine too. Sucks.
1979 KZ1000 Shaft
1979 CX500C
1975 GT750 Smoker
  • jbalet666
13 Mar 2013 18:04
#576848
DesertKZ wrote: Ugh, I have to redo one of mine too. Sucks.
Yeah mines gonna be done next week but I have to do both of mine
Have you ever done it before?
81 650csr
AoA
  • DesertKZ
  • DesertKZ's Avatar
14 Mar 2013 00:32
#576884
Not on this bike. The PO did these right before I bought it. Any write ups out there?
1979 KZ1000 Shaft
1979 CX500C
1975 GT750 Smoker
