1977 KZ 1000 "Brat Style" Project
  • bratbiker
  • bratbiker's Avatar Topic Author
Re: 1977 KZ 1000 "Brat Style" Project
02 Apr 2014 19:24
#627600
Well I'm hoping they perform well. I also put Dyna Beads in them rather than weight balancing, used them in my last set of tires and I never had a vibration right to the day I sold that bike.
  • bratbiker
30 Apr 2014 19:34
#630973
Well I've been busy tinkering again, and not updating so time for a power update.
I ordered a headlight and mounted with some sort of old Harley D bracket I found at the wrecking yard and 2 - $4 stainless "T" clamps.
Attachment 20140412_124416.jpg not found
Attachment 20140412_124354.jpg not found
Attachment 20140412_124347.jpg not found
Of course I'll have to shorten the bolts and get some nicer looking hardware but the overall look is not bad I think.
  • bratbiker
30 Apr 2014 19:50 - 30 Apr 2014 19:51
#630976
Decided to get to work on my foot controls, I had to order a longer rear brake line and weld on a new tab to attach the fluid reservoir. That solved my rear braking issues and I was able to utilize the whole braking system from the CBR954RR.
Attachment 20140428_202114.jpg not found
I'll have to work with the cable routing a bit though...
The shifter side took a bit of thinking, but I think I figured it out by using the original shifter shortened down and with yet another $5 piece of shift linkage I picked up from the old Harley bone yard. Also I Put on some 11" shocks that you might of noticed in the earlier pics so I ended up relocating and shortening the side stand to allow everything to function proper.
Attachment 20140428_202207.jpg not found
Last edit: 30 Apr 2014 19:51 by bratbiker.
  • bratbiker
30 Apr 2014 19:56
#630978
Got a New Clock too.... Just haven't figured out the mounting yet. Very pretty, and GPS as well.
Attachment 20140428_202301.jpg not found
  • bratbiker
30 Apr 2014 20:06
#630979
I know a lot of purists are going to hate this but I like the look, so a little chop to the frame was necessary, I ended up taking off most of the tabs and welded in a loop and new flat cross member to accommodate my seat. (which will be a surprise for you all once I see if my idea will actually work)
Attachment 20140428_202128.jpg not found
Attachment 20140428_202222.jpg not found
  • 531blackbanshee
  • 531blackbanshee's Avatar
  • Vendor
  • Vendor
01 May 2014 05:34
#631008
your getting there,keep up the good work!
and show us the pictures :P !!!!!!!!!!
  • bratbiker
01 May 2014 18:01
#631068
I'm thinking I just want to get it on the road for the summer, work out all the bugs and tweeks. Come next winter I'll rip it apart and work on the beautifying.
  • 531blackbanshee
  • Vendor
  • Vendor
02 May 2014 06:26
#631114
hey nobody wants to miss any ride time. B)
the cool thing about doing what your talking about is that you get the bugs worked out while shakin it down riding this summer. :evil:
sounds like a plan,
  • bratbiker
11 Jun 2014 19:49
#636248
So measured out the inside of my frame under my seat and got the local tin basher to make me up a battery box.
Attachment 20140510_091832.jpg not found
Fit just perfect! Along with my Shorai battery.
Attachment 20140510_115934.jpg not found
And so the wiring begins....
  • bratbiker
11 Jun 2014 20:06
#636250
Built my seat. Turned out O.K. I'm not so keen on the upholstery job but it will do for the summer.
I took a standard 3/8 thick nylon kitchen cutting board which Got from the restaurant supply, cut it roughly to shape with a few extra inches around the frame.
Attachment 20140510_225457.jpg not found
I then took my trusty heat gun and started to shape. After a longer period of time than I was hoping for and a few tie down straps I got the shape to pretty much what I was hoping for.
Attachment 20140511_094118.jpg not found
Attachment 20140511_094105.jpg not found
Now, I shaped the board a fir bit more with my jig saw and disk sander. Unfortunately I was in a rush to get it upholstered and I forgot to take a pic of the finished seat pan but it fit perfect.
Yes... I did send it off to be covered, I didn't have the time or resources to do it my self... this time.
Attachment 20140527_083015.jpg not found
  • 531blackbanshee
  • Vendor
  • Vendor
12 Jun 2014 07:11
#636292
looks tuff, :evil:
and,
low :whistle:
  • 31goodtymes31
  • 31goodtymes31's Avatar
13 Jun 2014 20:46
#636556
Very nice project!!! you don't have any issues with the forks hitting the tank?
Roy
1979 Suzuki GS1000
1978 KZ1000 LTD
1977 kz1000 A1
1978 Kz1000 a2
2009 Yamaha vmax
The following user(s) said Thank You: bratbiker
