Brat-ish build: '81 KZ-440B
- jbeebe1
Re: Brat-ish build: '81 KZ-440B
14 Dec 2012 19:35 - 14 Dec 2012 21:11cmazzoni16 wrote: Looks great! What did you do with the front master cylinder? I just replaced my bars and they are to short for the large master cylinder.
I started changing them tonight but ran into the master cylinder being to large.
like ed said, i have the cheapo kz440-B, which was the economy model. no discs for me!
also, I put the cyl head cover back on this afternoon. The manual says to adjust the valve clearances at the very end after putting everything back together, but I didn't remove the rocker shaft or anything, so would i still need to? i didn't adjust them, so if I made a mistake let me know
79 Honda 400 Hondamatic
79 Honda CB650
81 Honda CX500
81 Honda Passport C70
others coming in and out all the time!
79 Honda CB650
81 Honda CX500
Last edit: 14 Dec 2012 21:11 by jbeebe1.
- Nebr_Rex
14 Dec 2012 22:44
If you remove the rocker box,recheck your valve lash.
Just like retorqing the head,always double check your work.
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
- jbeebe1
15 Dec 2012 00:03 - 15 Dec 2012 11:30Nebr_Rex wrote: If you remove the rocker box,recheck your valve lash.
I only removed the head cover, i didn't touch the rockers or rocker shafts, so i just can't believe that anything could change without touching the screw and locknut. hmmm....but I should probably be safe than sorry
79 Honda CB650
81 Honda CX500
79 Honda CB650
81 Honda CX500
Last edit: 15 Dec 2012 11:30 by jbeebe1.
- jbeebe1
30 Dec 2012 20:45 - 31 Dec 2012 11:56
Well I mustered the patience today to replace the fork seals. I followed the FSM and also a few threads about it, all-in-all it wen't pretty smooth. The hardest part for me was removing that dang wire retaining clip for the top plug. Pushing it down, in order to get to the clip proved pretty difficult. I had to soak it in PB Blaster, torch it, then put it back in the triples to break it free until it could push down. I guess after sitting for 31 years like that, it was little stubborn to move.
Only about half of the proper amount of fluid came out when draining, so it was definitely due. The front felt really soft before.
I opted to use Ams-Oil synthetic 10w-30 instead of ATF or fork oil (no mc shops were open today). I weigh 180 and drive pretty aggressively, so I think i'll like the stiffer feel.
The seals didn't look too bad actually, but while its all apart to change the fluid, I might as well pop the old ones out. I had to heat up the fork tube around the seal before I could pry it out with a claw hammer.
Old:
I also decided to put on some fork gaiters instead of dust boots, and paint the forks black. Eventually the entire wheel and spokes will be black too.
I'll update with pic once the front wheel is back on. I still need to put on new tires, rear brakes, sprockets and chain sometime this winter.
Old:
79 Honda CB650
81 Honda CX500
79 Honda CB650
81 Honda CX500
Last edit: 31 Dec 2012 11:56 by jbeebe1.
- jbeebe1
31 Dec 2012 18:46 - 31 Dec 2012 18:46
Alright well here she is. The only issue yet is I think i screwed up the whole "brake pad synchronization" thing, as they aren't functioning up front properly after following the steps in the the fsm. I guess i'll repeat that later.
79 Honda CB650
81 Honda CX500
79 Honda CB650
81 Honda CX500
Last edit: 31 Dec 2012 18:46 by jbeebe1.
- Spitfire151
- jbeebe1
10 Mar 2013 16:09 - 10 Mar 2013 16:15
Last week I took care of all the oil leaks she had:
right side crank gasket, oil pressure switch, engine cover gaskets again, left side shift rod gaskets.
I also finally adjusted the front brake to where I feel somewhat safe.
We had 60 degrees here in Cleveland today, so out she went!
I have new sprockets and chain on order.
Do you guys think I should repaint the tank? All gloss black?
79 Honda CB650
81 Honda CX500
79 Honda CB650
81 Honda CX500
Last edit: 10 Mar 2013 16:15 by jbeebe1.
- Nebr_Rex
10 Mar 2013 17:32
How about some color matching pin striping on the front fender and side covers?
2002 ZRX1200R
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
- jbeebe1
12 Mar 2013 16:49Nebr_Rex wrote: How about some color matching pin striping on the front fender and side covers?
That would look good, but i'm going for more of the black death look. I want to eventually paint the wheels all black as well. Maybe I should do the tank in a dark silver.
79 Honda CB650
81 Honda CX500
79 Honda CB650
81 Honda CX500
- jbeebe1
30 Mar 2013 13:16
well I got done with the last bit of stuff (minus the seat, which will come when I find someone with a welder). I got new tires put on (the only work i didn't do myself on the whole thing), painted the wheels, and replaced sprockets and chain. I also cut off the passenger foot pegs and support tubes, so it cleans up the frame a lot in the back.
Check out some Day 1 >>> Today pics:
I'm probably going to paint the tank a dark gunmetal color in the future as well.
79 Honda CB650
81 Honda CX500
79 Honda CB650
81 Honda CX500
- nitsua93
- I brake things.
30 Mar 2013 13:44
I like it bro! I think you should leave the tank the way it is. It has that old British look to it.
I can't leave this blank.
- catseye
Re: $270 build! '81 KZ-440B
30 Mar 2013 15:04 - 30 Mar 2013 15:05I encountered the same "Don't do it!!" on the Honda forum before I did this to my CB750:tjgonz wrote: Maybe Ive gotten lucky but my bike runs primo with pods..
Properly tuned and jetted, It ran better than before. MUCH better.
I am now building a KZ1100, will do the same thing and see if it works....if it does, I will start or contribute to an existing "pod" thread, if not, I will keep my mouth shut...
BTW, front and rear wheels look familiar?
1982 KZ750LTD
1976 BMW R90/6
1982 Honda CBX
1976 BMW R90/6
1982 Honda CBX
Last edit: 30 Mar 2013 15:05 by catseye.
