1980 KZ 1000 B4 LTD 1327 Build
- wireman
Re: 1980 KZ 1000 B4 LTD 1327 Build
09 Mar 2013 23:13
My guess would be cocaine /a lot of sand paper and a dremel! :woohoo:
- Powerstroke_fan
10 Mar 2013 11:08
wireman would be correct lol well ok maybe not the coke. but beer deffitenly had a factor. No i had the cases completely split and everything apart. I started by sandblasting with 60/80 grit glass bead. Then i sanded it with sand paper and various sanding pad tools like a 7 in 1 tool and dremel and i also had really good luck with abrasive wheels to fit a standard drill and one on a dremel to fit in the nooks and crannys. Anyway went up to 800 grit dry then i wet sanded 800 and 1000 grit using wd 40 as my water. I was told by a old timer to try it. So i did and it seemed to work pretty decent. But anyway after that was done it will have most the scratches out only a few small sandpaper marks. Then i used a buffing kit i had bought from harbor freight long ago. using various ends to get in diffrent places. Anyway i used a polish around here that is popular with alot of the harley guys. Its called white diamond. Its a polish/protectant. That brought out the mirror like reflection and removing 99% of the scratch marks. Then to get the really bright and shinely surface you see there, I cleaned it all up with brake cleen and then buffed it again with mothers aluminum polish. The white diamond is a more aggressive grit but preps the surface really well for the mothers to finish it off. Its deffitenly alot of work, i wont lie. I worked on my slowly all winter. And doing this power tools are your best friend. The more types you have the better.Well hope that helps if you have any more questions feel free to ask.
1977 KZ 1000 work in progress
- nivlac
11 Mar 2013 08:42
Good looking ride. Nice job on that polishing.
1983 kz1100
1979 cb650
1979 cb650
- Powerstroke_fan
11 Mar 2013 16:32
Thank you, Its alot of work.
- Powerstroke_fan
07 Apr 2013 21:38
well guys i got the bike all back together today and got it running and man i gotta say DAMN!!!!!! this bike is a beast. Burn outs, NO problem. wheelies, No problem. Just rolling on the throttle will smoke the tire. I havent even gave it more than half throttle yet. This bike is wicked fast. Tommorrow i will get some pictures.
- wireman
07 Apr 2013 21:54Attachment quag_2013-04-07.jpg not found
- jonarmstrong
07 Apr 2013 23:19
Awesome build! Great job
82 Kz1000 gpz1100 cams dyna ignition kerker k&n
- mark1122
- Keep twisting it
08 Apr 2013 09:58
U may want to consider increasing the crank case venting capacity with those big pistons. it will help to keep it from seeping oil down the road.
Congrats on a great build.
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- Powerstroke_fan
08 Apr 2013 22:37
Thank you mark1122, I actually took your advice long ago and ended up using the old emission caps in the valve cover and flipped the reed valve over so it can only blow out now. I then T'd the two together and ran it down with 3/4 heater hose and T'd it into the crankcase vent then down between the swing arm and frame.
- Powerstroke_fan
08 Apr 2013 22:43
Now, As i promised here are a few photos of the finished (for now) bike. I will be adding the oil cooler soon along with a few other minor stuff.
Attachment IMG_0418.JPG not found
Attachment IMG_0419.JPG not found
Attachment IMG_0420.JPG not found
Attachment IMG_0421.JPG not found
Attachment IMG_0422.JPG not found
Attachment IMG_0423.JPG not found
Attachment IMG_0424.JPG not found
Attachment IMG_0425.JPG not found
- Powerstroke_fan
08 Apr 2013 22:44
one last one for now.
- Powerstroke_fan
08 Apr 2013 22:45
Attachment IMG_0426_2013-04-08.JPG not found
